some question on porting rtems on sparc v8
Tue Dec 8 14:07:12 UTC 2015
On Dec 8, 2015 7:59 AM, "Gavin Gu" <jackgurong at gmail.com> wrote:
> Hi,
> I'm already build and install rtems on my ubuntu. Refer to some guides
there must have some test samples under install dir. my install dir is
"$HOME/development/rtems/leon3/4.11",I checked every single dir under
"/development/rtems/leon3/4.11/"  there is no test samples.But to my
confuse, the test samples under the build dir which is
"$HOME/development/rtems/b-leon3/sparc-rtems4.11/c/leon3/testsuites/samples/".I
chose ticker.exe sample and use tsim-leon3.exe to simulator. I got the
result. am I correct?
Did you do a make install on RTEMS?
If you did and they still were not in the install point, the guide(s) needs
refreshing. In this case, please file a ticket.
If ticker ran from the build tree, that's a really good indicator that the
build was OK.
> I'm a newer to rtems, and I don't know how to make a kernel image to
flash it on my target. there is no ".exe" or ".bin" file under rtems
install dir to make a kernel image. I don't get the idea.
> thinks!
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20151208/e1e85762/attachment-0002.html>
