some question on porting rtems on sparc v8
Gavin Gu
jackgurong at gmail.com
Tue Dec 8 13:59:25 UTC 2015
Hi,
I'm already build and install rtems on my ubuntu. Refer to some guides
there must have some test samples under install dir. my install dir is
"$HOME/development/rtems/leon3/4.11",I checked every single dir under
"/development/rtems/leon3/4.11/" there is no test samples.But to my
confuse, the test samples under the build dir which is
"$HOME/development/rtems/b-leon3/sparc-rtems4.11/c/leon3/testsuites/samples/".I
chose ticker.exe sample and use tsim-leon3.exe to simulator. I got the
result. am I correct?
I'm a newer to rtems, and I don't know how to make a kernel image to flash
it on my target. there is no ".exe" or ".bin" file under rtems install dir
to make a kernel image. I don't get the idea.
thinks!
URL: <http://lists.rtems.org/pipermail/users/attachments/20151208/dd5857d1/attachment.html>
