Unable to build sparc toolset
Gedare Bloom
gedare at rtems.org
Wed Dec 9 12:43:02 UTC 2015
On Wed, Dec 9, 2015 at 6:38 AM, Sambeet Panigrahi <sambeet161616 at gmail.com>
wrote:
> >On Tue, 2015-12-08 at 10:48 -0500, Gedare Bloom wrote:
> > And if you want to kill it, I would send a kill signal to the process
> >As Gedare's alluding to, the Ctrl-Z is probably a problem here... It'll
> >typically suspend a process, so it's still running.
> >Ctrl-C to kill :-)
> I realised my mistake and killed the process and rebuilt it.But the
> problem still exists as my firewall prevents the git protocol.The build
> failed again with the error in the error report given as
> Creating source directory: sources/git
> making dir:
> /home/sambeet/development/rtems/src/rtems-source-builder/rtems/sources/git
> git: clone: git://git.rtems.org/rtems-tools.git ->
> sources/git/rtems-tools.git
> error: git command failed (/usr/bin/git): 128
> As previously Nick and Joel has suggested I tried to manually clone the
> filles into sources directory under
> development/rtems/src/rtems-source-builder/rtems and tried building
> again.But the process still tries to clone from the terminal.The last few
> lines before the build fails are
> Build FAILED
> See error report: rsb-report-rtems-tools-HEAD-1.txt
> Build Set: Time 1:14:56.847676
> Build FAILED
> I also tried to clone the contents into a .git directory using git init
> because of the following line
> but the process still tries to clone it, giving back the same error. How
> do we get around this?
> RSB always assumes it should restart fresh. Ithink there may be an option
not to restart/download, and it will look for the sources in the current
directory, but I could be mistaken. Another more complicated option would
be to copy and modify the .cfg files in RSB to either point them to
downloadable files or to an internal git clone url.
> There's another problem also about the build time which in my machine
> takes approximately an hour as mentioned above. Is my machine slower than
> required?
> This is normal to build gcc.
> I am really sorry for being verbose.I am a newbie and just want to learn
> properly.☺
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20151209/cabfc407/attachment-0002.html>
