RTEMS on Beaglebone Black
angelo fraietta
newsgroups at smartcontroller.com.au
Mon Feb 16 06:15:26 UTC 2015
Greetings
Have you got interrupts working on the GPIOs. Also, do you have any
sample of reading and writing to GPIO. I need to see whether it is going
to be fast enough,
I ran a program (on linux) on beagle that used registers basically
toggling an output. EG
http://vabi-robotics.blogspot.com.au/2013/10/register-access-to-gpios-of-beaglebone.html
It toggled at rate of just under 1Mhz, and what was just doing a while 1
loop. I did not look even look at interrupts there and did nothing else
- I didn't even do any reads of GPIO.
I want to get interrupts happening at 1.56Mhz (preferable) and read 14
GPOI, sbut I could go to half the rate by reducing my sample rate. The
beagle runs at 1Ghz, so I think it should be able to handle it.
Thanks
On 23/01/2015 4:19 PM, Ben Gras wrote:
> All,
> A while ago I finished the basics needed to use the beaglebones and
> beagleboards with RTEMS. The hardware support isn't very complete yet.
> The code is merged with RTEMS mainline though. My fork of rtems-tools
> and RSB is needed for help with building.
> Full details on how to build it are here:
> http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html
> I hope you like it :-). Let me know if you'd like any followup.
> Cheers,
> Ben
> On Thu, Jan 22, 2015 at 4:46 AM, angelo fraietta
> <newsgroups at smartcontroller.com.au> wrote:
>> Greetings
>> Does anyone know the status of the beaglebone port?
>> Thanks
>> This email has been checked for viruses by Avast antivirus software.
>> http://www.avast.com
>> users mailing list
>> users at rtems.org
Dr Angelo Fraietta
A.Eng, A.Mus.A, BA(Hons), Ph.D.
PO Box 859
Hamilton NSW 2303
Home Page
http://www.smartcontroller.com.au/
There are those who seek knowledge for the sake of knowledge - that is
CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
Bernard of Clairvaux (1090 - 1153)
