RTEMS on Beaglebone Black
Mathew Benson mathew.benson at gmail.com
Mon Feb 16 06:34:59 UTC 2015
You're doing that in the CPU?  If all your doing is toggling a GPIO at a steady rate, why don't you just use the PRU and a PWM pin?  Or do you have RTEMS running in the PRU?
Sent from my iPad
> On Feb 16, 2015, at 12:15 AM, angelo fraietta <newsgroups at smartcontroller.com.au> wrote:
> Greetings
> Have you got interrupts working on the GPIOs. Also, do you have any sample of reading and writing to GPIO. I need to see whether it is going to be fast enough,
> I ran a program (on linux) on beagle that used registers basically toggling an output. EG
> http://vabi-robotics.blogspot.com.au/2013/10/register-access-to-gpios-of-beaglebone.html
> It toggled at rate of just under 1Mhz, and what was just doing a while 1 loop. I did not look even look at interrupts there and did nothing else - I didn't even do any reads of GPIO.
> I want to get interrupts happening at 1.56Mhz (preferable) and read 14 GPOI, sbut I could go to half the rate by reducing my sample rate.  The beagle runs at 1Ghz, so I think it should be able to handle it.
> Thanks
>> On 23/01/2015 4:19 PM, Ben Gras wrote:
>> All,
>> A while ago I finished the basics needed to use the beaglebones and
>> beagleboards with RTEMS. The hardware support isn't very complete yet.
>> The code is merged with RTEMS mainline though. My fork of rtems-tools
>> and RSB is needed for help with building.
>> Full details on how to build it are here:
>> http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html
>> I hope you like it :-). Let me know if you'd like any followup.
>> Cheers,
>> Ben
>> On Thu, Jan 22, 2015 at 4:46 AM, angelo fraietta
>>> Greetings
>>> Does anyone know the status of the beaglebone port?
>>> Thanks
>>> This email has been checked for viruses by Avast antivirus software.
>>> http://www.avast.com
>>> users mailing list
>>> users at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/users
> Dr Angelo Fraietta
> A.Eng, A.Mus.A, BA(Hons), Ph.D.
> PO Box 859
> Hamilton NSW 2303
> Home Page
> http://www.smartcontroller.com.au/
> There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
> There are those who seek knowledge to be known by others - that is VANITY
> There are those who seek knowledge in order to serve - that is LOVE
>    Bernard of Clairvaux (1090 - 1153)
> users mailing list
> users at rtems.org
