building example programs
Sun Feb 22 14:29:09 UTC 2015
Andrew,
You probably need to rm -r b-beagle and redo everything from there.
The old build is probably still in place and being used. (In theory,
make distclean in b-beagle should work too. But rm is a more certain
way to clean.)
Gedare
On Sat, Feb 21, 2015 at 3:27 PM, Andrew Harris <andrew.unit at gmail.com> wrote:
> Hi Joel,
>    Thanks for the response, I don't think I see anything wrong with the
> typing.  When I run the configure line I mentioned, and then do make
> install, I actually get a bin/ directory in the "just_a_test" directory that
> I set as the prefix, and it has the following files in it:
> "arm-rtems4.11-difftest  arm-rtems4.11-sorttimes  cklength  eolstrip
> install-if-change  packhex  rtems-bin2c  unhex".  It's not until it gets to
> the beagleboneblack step that it seems the prefix isn't propagated.
> -andrew
> On Sat, Feb 21, 2015 at 3:14 PM, Joel Sherrill <joel.sherrill at oarcorp.com>
> wrote:
>> On February 21, 2015 2:02:52 PM CST, Andrew Harris <andrew.unit at gmail.com>
>> wrote:
>> >Hi Gedare,
>> >Thanks for the suggestion, I think I understand what you're saying.  I
>> >went back to the article, and made a slight modification to the
>> >configure line that was specified; I added a prefix ("just_a_test") to
>> >see what would happen when I did a make install:
>> >CONSOLE_POLLED=1 ../rtems-src/configure --target=arm-rtems4.11
>> >--enable-rtemsbsp="beagleboneblack" --enable-tests
>> >--prefix=$HOME/development/rtems/just_a_test
>> >It got pretty far, but I found that there must be an error in one of
>> >the configuration steps below this call, because it looks like the
>> >prefix I specified didn't make it all the way down to the BSP, where it
>> >is still apparently trying to install into /opt/rtems-4.11:
>> Double check the typing on the --prefix option. The configure script is
>> acting like it wasn't provided.
>> >Making install in beagleboneblack
>> >make[2]: Entering directory
>> >`/home/andrew/development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack'
>> >Making install in .
>> >make[3]: Entering directory
>> >make[4]: Entering directory
>> >make[4]: Nothing to be done for `install-exec-am'.
>> > /bin/mkdir -p '/opt/rtems-4.11/lib/pkgconfig'
>> >/bin/mkdir: cannot create directory ‘/opt/rtems-4.11’: Permission
>> >denied
>> >make[4]: *** [install-pkgconfigDATA] Error 1
>> >make[4]: Leaving directory
>> >make[3]: *** [install-am] Error 2
>> >make[3]: Leaving directory
>> >make[2]: *** [install-recursive] Error 1
>> >make[2]: Leaving directory
>> >make[1]: *** [install-recursive] Error 1
>> >make[1]: Leaving directory
>> >`/home/andrew/development/rtems/b-beagle/arm-rtems4.11/c'
>> >make: *** [install-recursive] Error 1
>> >So I'm stuck again; I'm not sure where to look to try to find where the
>> >prefix argument isn't handed off correctly.
>> >-andrew
>> >On Sat, Feb 21, 2015 at 2:20 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> >Hi Andrew,
>> >Have you installed the compiled RTEMS and BSPs via "make install" e.g.
>> >in your ~/development/rtems/b-beagle directory?
>> >The waf script will only find BSPs that are installed in the directory
>> >you tell it to look e.g. ~/development/rtems/4.11
>> >Gedare
>> >On Sat, Feb 21, 2015 at 9:48 AM, Andrew Harris <andrew.unit at gmail.com>
>> >wrote:
>> >> Hello,
>> >>    Thanks for the useful information.  I'm still having a heck of a
>> >time
>> >> getting the examples to build.  I can't seem to get my "waf
>> >configure" line
>> >> to work out.  I got RTEMS working from the nice article on this site:
>> > >http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html
>> >> But I fear I don't understand now how to specify the waf configure
>> >line.
>> >> I've got it so that it doesn't complain about the RTEMS path, nor
>> >does it
>> >> complain about the RTEMS tools path:
>> >> ~/development/rtems/rtems-tools/waf configure
>> >> --rtems=$HOME/development/rtems/4.11
>> >> --rtems-tools=$HOME/development/rtems/4.11
>> >> But I can't seem to figure out how to tell it to use the
>> >beagleboneblack
>> >> BSP.  I have added some print statements into the rtems.py file which
>> >I
>> >> believe is used by the waf build system and it doesn't seem to see
>> >any bsps
>> >> at all in the paths I've specified above.
>> >> However, from the website article, it seems to build in such a way as
>> >to
>> >> create a b-beagle directory, and deep inside that directory I do see
>> >a
>> >> directory that contains a ".pc" file, which I presume is a key file
>> >for the
>> >> BSP:
>> > >development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack/arm-rtems4.11-beagleboneblack.pc
>> >> But I can't seem to figure out how to combine this knowledge with the
>> >> directories that are required for the waf configure step.
>> >> Has anyone gotten stuck here before?  If so, any help would be
>> >appreciated!
>> >> thanks,
>> >> -andrew
>> >> On Wed, Feb 18, 2015 at 9:02 AM, Gedare Bloom <gedare at rtems.org>
>> >wrote:
>> >>> Hi Andrew,
>> >>> The examples located in testsuites are intended to be compiled with
>> >>> RTEMS and will not work by copying them elsewhere. For compiling an
>> >>> application, you should have a look at the examples-v2.git
>> >repository
>> >>> [1]. That should have more info about using RTEMS_MAKEFILE_PATH, and
>> >>> also has a newer approach to compiling applications for RTEMS that
>> >>> uses the Waf build system. I highly recommend checking out the
>> >>> waf-based approach to compiling applications as it has some great
>> >>> features, albeit at a slight learning curve.
>> >>> Gedare
>> >>> [1] https://git.rtems.org/examples-v2/
>> >>> On Tue, Feb 17, 2015 at 8:16 PM, Andrew Harris
>> >>> wrote:
>> >>> > Hello,  I'm trying to figure out how to start a new RTEMS
>> >application.
>> >>> > I
>> >>> > thought I would start by looking at the ticker example.  I copied
>> >the
>> >>> > ticker
>> >>> > example but I am not sure how to compile it.  I am not an expert
>> >in
>> >>> > autoconf/automake and could use some assistance on how to get
>> >started.
>> >>> > I
>> >>> > think I figured out how to configure my RTEMS_MAKEFILE_PATH
>> >variable,
>> >>> > but
>> >>> > the only two files in the ticker example are Makefile.am and
>> >>> > Makefile.in,
>> >>> > and I don't know what to do next to build it.  Any help would be
>> >>> > appreciated!
>> >>> > -andrew
>> >>> > _______________________________________________
>> >>> > users mailing list
>> >>> > users at rtems.org
>> >>> > http://lists.rtems.org/mailman/listinfo/users
>> >> users mailing list
>> >> users at rtems.org
>> --joel
