building example programs
Andrew Harris
andrew.unit at gmail.com
Sun Feb 22 15:59:53 UTC 2015
Hi Joel,
Thanks, I'm not a waf expert but I was able to comment out the
bld.recurse('hello') line in the build function and that seems to have
removed the hello examples from building, and now the process completes
OK. Thanks for the help.
-andrew
On Sun, Feb 22, 2015 at 10:43 AM, Joel Sherrill <joel.sherrill at oarcorp.com>
wrote:
> On February 22, 2015 10:41:55 AM EST, Andrew Harris <andrew.unit at gmail.com>
> wrote:
> >On Sun, Feb 22, 2015 at 10:34 AM, Joel Sherrill
> ><joel.sherrill at oarcorp.com> wrote:
> >On February 22, 2015 10:29:38 AM EST, Andrew Harris
> ><andrew.unit at gmail.com> wrote:
> >>Hi Gedare,
> >>That worked, thanks. I was then able to get the "waf configure" step
> >>to work in the examples-v2 directory by using the following line:
> >>~/development/rtems/rtems-tools/waf configure
> >>--rtems=$HOME/development/rtems/just_a_test
> >>--rtems-tools=$HOME/development/rtems/4.11
> >>--rtems-bsps=arm/beagleboneblack
> >>And the waf configure seems to have worked. However, when I try to
> >run
> >>the "waf" step to build everything in examples-v2, it gets really far,
> >>but stops on step 96 of 116 with a linker error. Does this error look
> >>like a configuration problem or is it something that might be just
> >>wrong with one of the examples which I should just skip over? One
> >>wierd thing I noticed was that the "hello-deep.c" file that it was
> >>talking about is a filename with an initial space which threw me for a
> >>loop for a minute!
> >I think this may be a recent modification of a simple example to show
> >off the trace linker. There is a PR I think to revert that change.
> >Did fixing the space let it continue?
> >Hi Joel,
> >The hello-deep.c file seems to be autogenerated, so I'm not quite sure
> >where to look to fix it. If you have a suggestion on where to look I
> >can give it a try.
> I am in the Atlanta airport so would recommend just dropping the directory
> out of the set built.
> >-andrew
> --joel
URL: <http://lists.rtems.org/pipermail/users/attachments/20150222/4f7b20f8/attachment-0001.html>
