RTEMS Source Builder: native-elf-format.h not found
Thu Jan 22 04:19:50 UTC 2015
On 22/01/2015 10:31 am, Tyler Parks wrote:
>      I believe it was
> rtems-source-builder/rtems/config/tools/rtems-gcc-4.8.2-newlib-cvs-1.cfg
> said "incompatible makeinfo version found" when I had texinfo v5.1
> installed (texinfo includes makeinfo). I opened that config file in vim,
> and around line 23 it says to give errors for any version number >= 5.0.
>       I removed texinfo v5.1 and installed texinfo v4.13. I installed
> v4.13 from source because Fedora's yum repos only hold the latest
> version. After a reboot, the RTEMS Source Builder was able to build all
> the tools successfully.
Thanks for this. This is going to be a little difficult to sort out.
Maybe the RSB needs to build and install texinfo or we look at not
building the doco. Joel what do you think ?
>      I can update the note for Fedora hosts in the Hosts section of
> source-builder.txt, if that's what you're asking, although I'm not sure
> how to submit it. I've got a class soon, but I'll look over
> https://devel.rtems.org/wiki/Developer/GitUsers#SubmittingaPatch in more
> detail later and try to submit it tonight.
Typically make the change and commit it then get git to email the
devel at rtems.org list with the commit.
