nfsMount - mount: Not supported
Wed Jul 8 00:25:41 UTC 2015
On 8/07/2015 8:51 am, Ben Dart wrote:
> So I managed to get the nfs library to link. I also added a free driver
> so I think that I am running NFS successfully. Problem is now that I am
> not able to connect to an NFS server.
> 1.      I have set up a server on an XP computer using Omni-NFS server
> and am able to connect to it from an old linux computer.
Does this NFS server support NFS v2 ? Some more recent server do not
support v2 which is all RTEMS currently support.
> 2.      I tried the following commands in the RTEMS shell:
> a.      mount -t nfs 172.21.3.235:/ /D/NFS
> b.      mount -t nfs 172.21.3.235:c:/test/ /D/NFS
> c.      mount -t nfs 172.21.3.235:/c/test/ /D/NFS
> 3.      I get the following response:
> RTEMS-RPCIOD $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See
> LICENSE file for licensing info.
> RTEMS-NFS $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See
> Trying to mount 172.21.3.235: on /D/NFS
> The folder /D/NFS is created successfully so I know at least that the
> mount path on the device running RTEMS is correct.
> From a quick look and some printing in the source code I noticed that
> rtems is mounting (assumably) through something similar to the linux
> “mount” command under “nfsMount(…” in nfs.c:
>       int varRes = mount(&mtab,
>                     &nfs_fs_ops,
>                     RTEMS_FILESYSTEM_READ_WRITE,
>                     dev,
>                     mntpoint);
>       fprintf(stderr, "BEN NOTE: trying to mount: %d\n", varRes);
>       if (varRes) {
>             perror("nfsMount - mount");
>             goto cleanup;
> Note that I added the print statement. We are getting an error from the
> mount command of “-1” which from the following man page:
> http://linux.die.net/man/8/mount
> Doesn’t seem to be an actual error code of mount?
> I am trying to use RTEMS 4.9.2 on a powerPC MPC5200.
> Ben
> users mailing list
> users at rtems.org
