enable-smp on xilinx_zynq_zedboard
Ric Claus
claus at slac.stanford.edu
Mon Jul 20 19:25:28 UTC 2015
Hello All,
Today I git cloned the RTEMS master and configured with:
../../src/rtems/configure --target=arm-rtems4.11 --enable-posix \
--enable-networking --enable-cxx --enable-maintainer-mode --enable-tests \
--enable-rtemsbsp=xilinx_zynq_zedboard --enable-smp \
--prefix=/home/claus/development/rtems/4.11 BSP_PRINT_EXCEPTION_CONTEXT=1
and built. The build failed with:
arm-rtems4.11-gcc -B../../../../../xilinx_zynq_zedboard/lib/ -specs bsp_specs -qrtems -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -o hello.exe init.o
../../../../../xilinx_zynq_zedboard/lib/librtemsbsp.a(libbsp_a-cache_manager.o): In function `arm_cache_l1_get_data_cache_size':
/home/claus/development/rtems/bld/xilinx_zynq/zedboard/smp/arm-rtems4.11/c/xilinx_zynq_zedboard/lib/libbsp/arm/xilinx-zynq/../../../../../../../../../../../src/rtems/c/src/lib/libbsp/arm/xilinx-zynq/../shared/arm-l2c-310/../include/arm-cache-l1.h:380: undefined reference to `rtems_interrupt_disable'
/home/claus/development/rtems/bld/xilinx_zynq/zedboard/smp/arm-rtems4.11/c/xilinx_zynq_zedboard/lib/libbsp/arm/xilinx-zynq/../../../../../../../../../../../src/rtems/c/src/lib/libbsp/arm/xilinx-zynq/../shared/arm-l2c-310/../include/arm-cache-l1.h:386: undefined reference to `rtems_interrupt_enable'
../../../../../xilinx_zynq_zedboard/lib/librtemsbsp.a(libbsp_a-cache_manager.o): In function `arm_cache_l1_get_instruction_cache_size':
/home/claus/development/rtems/bld/xilinx_zynq/zedboard/smp/arm-rtems4.11/c/xilinx_zynq_zedboard/lib/libbsp/arm/xilinx-zynq/../../../../../../../../../../../src/rtems/c/src/lib/libbsp/arm/xilinx-zynq/../shared/arm-l2c-310/../include/arm-cache-l1.h:401: undefined reference to `rtems_interrupt_disable'
/home/claus/development/rtems/bld/xilinx_zynq/zedboard/smp/arm-rtems4.11/c/xilinx_zynq_zedboard/lib/libbsp/arm/xilinx-zynq/../../../../../../../../../../../src/rtems/c/src/lib/libbsp/arm/xilinx-zynq/../shared/arm-l2c-310/../include/arm-cache-l1.h:407: undefined reference to `rtems_interrupt_enable’
I remember Sebastian’s patch email titled "[PATCH] rtems: Add rtems_interrupt_local_disable|enable()” of a month ago. Since the L1 cache functions of the Zynq are visible only to the local core, is it appropriate to replace the rtems_interrupt_disable|enable functions with rtems_interrupt_local_disable|enable in this file? Or do we need a more involved solution, in which case, could I please get some guidance?
Thanks very much!
Cheers,
Ric
