net-snmp using RSB
Cen Zhao cenzhao at fb.com
Thu Jul 23 16:47:04 UTC 2015
rtems-net-snmp-5.7.2.1-20140623.patch does have indicated snmpd_init
function was added,
However, its not present in the source code
(rtems/sources/net-snmp-5.7.2.1.tar.gz).
Cen
On 7/22/15, 4:18 PM, "users on behalf of Chris Johns"
<users-bounces at rtems.org on behalf of chrisj at rtems.org> wrote:
>On 23/07/2015 1:59 am, Adit Sahasrabudhe wrote:
>> One thing I still don¹t understand is that in the link you sent in a
>> previous email to the patch you put in the repository, snmpd_init() is
>> shown in there. However, when we grep our net-snmp source that the RSB
>> uses, it finds nothing. Why this discrepancy?
>Did you check the patches directory ?
>If you add --no-clean the source as built will be left in the build tree.
>Chris
>_______________________________________________
>users mailing list
>users at rtems.org
>https://urldefense.proofpoint.com/v1/url?u=http://lists.rtems.org/mailman/
>listinfo/users&k=ZVNjlDMF0FElm4dQtryO4A%3D%3D%0A&r=36pazbxeUPhcsxOFws5axw%
>3D%3D%0A&m=pRGIHTEKp48FCuKUf0PJXPNgfs%2BdyDj2TCPqFy5vv3U%3D%0A&s=e25c513e7
>7f290137f65c9be52a40024ca286e2c885cbbda1cafe6df03e1e4a3
