net-snmp using RSB
Fri Jul 24 05:39:24 UTC 2015
On 24/07/2015 2:47 am, Cen Zhao wrote:
> rtems-net-snmp-5.7.2.1-20140623.patch does have indicated snmpd_init
> function was added,
> However, its not present in the source code
> (rtems/sources/net-snmp-5.7.2.1.tar.gz).
The RSB builds a package based on original upstream source plus any
local patches. We do not patch upstream packages and repackage as a new
tarball. As a result the code that is built is made up the tar file
source with the patch applied.
