C User's Guide Info dir entry
Albert Huang
alberthuang314 at gmail.com
Fri Jul 31 09:52:16 UTC 2015
Hi, all,
I usually read RTEMS document in Info file format, and I found that C
Users' Guide is not correctly set for its dir entry, and hence couldn't
be found after 'make install'. This is just a one line fix as follows:
In doc/user/c_user.texi:
-* RTEMS C User: (C Users Guide). The C User's Guide.
+* RTEMS C User: (c_user). The C User's Guide.
After this fix, configure with --enable-docs and make install, C Users'
Guide can be found by Emacs Info reader without modifying dir entry. Thanks.
Cheers,
Albert
