gsoc students
Wed Jun 3 15:10:48 UTC 2015
Always glad to hear about possible code coming back out. Is your I2C
driver using the newer driver framework in cpukit/dev/i2c?
One student is working on networking with libbsd and with that might
get USB for not much more effort. Another student is already working
on the GPIO peripherals, and plans to work on ADC after that, so there
won't be much duplication of effort.
Gedare
On Wed, Jun 3, 2015 at 10:48 AM, Andrew Harris <andrew.unit at gmail.com> wrote:
> Hi,
>    I was curious to see when they started and what they're going to work on.
> I'm new to BSP development, but I have working drivers for I2C, GPIO and PWM
> (I believe possibly for the BBBlack only).  Right now they're not building
> in the normal BSP directory, but in my project directory.  So I probably
> have a chunk of work still to do to get them building in the way the BSP
> expects.  I'm hoping to get them released back to RTEMS, but I have to work
> through my employer's public release process first.  I was curious to see
> when the students were going to start and what they were going to work on.
> I see one of the students would be working on the network stack.  If the
> other student worked on the ADC and USB drivers before working on I2C and
> GPIO, maybe we could avoid some duplication of effort.  Just a suggestion.
> -andrew
> On Wed, Jun 3, 2015 at 9:11 AM, Joel Sherrill <joel.sherrill at oarcorp.com>
> wrote:
>> On June 3, 2015 9:07:23 AM EDT, Anand Krishnan <anandkp92 at gmail.com>
>> wrote:
>> >Hi,
>> >The students have already started the  work. You can follow their
>> >progress at : https://devel.rtems.org/wiki/GSoC/2015
>> They are collectively adding device drivers to the BB BSP which already
>> supported all variants.
>> Andrew. What drivers are you must interested in?
>> >Thanks!
>> >Anand
>> >On Wed, Jun 3, 2015 at 6:17 PM, Andrew Harris <andrew.unit at gmail.com>
>> >wrote:
>> >Hi,
>> >I'm curious when the GSOC students will be starting work on the
>> >beaglebone BSP.  Does anyone have an idea?
>> >thanks,
>> >-andrew
>> >_______________________________________________
>> >users mailing list
>> >users at rtems.org
>> >http://lists.rtems.org/mailman/listinfo/users
>> --joel
> users mailing list
> users at rtems.org
