gsoc students
Fri Jun 5 16:08:05 UTC 2015
On Fri, Jun 5, 2015 at 11:46 AM, Andrew Harris <andrew.unit at gmail.com> wrote:
> Hi Gedare,
>    No I didn't know about the new framework in cpukit/dev/i2c.  I'll take a
Great!
> look.  Also, don't let me hamper any work the students are doing.  I'm
> working on getting it through public release, and I'm hopeful that I can
> contribute it back, but it's possible that it can't be released for some
> reason.  I'd hate to interfere with the work of the students in this case.
Thanks for being considerate. Without code in hand, I would never hold
up another developer, much less a student. Risk management 101. :)
Even if there is some duplication of effort the end result will end up
better, so no worries. All that said, I'll be quite pleased when the
students submit code if you can take some time to review. I'll try to
make a point of encouraging them to solicit your feedback!
Sincerely,
Gedare
> -andrew
> On Wed, Jun 3, 2015 at 11:10 AM, Gedare Bloom <gedare at rtems.org> wrote:
>> Always glad to hear about possible code coming back out. Is your I2C
>> driver using the newer driver framework in cpukit/dev/i2c?
>> One student is working on networking with libbsd and with that might
>> get USB for not much more effort. Another student is already working
>> on the GPIO peripherals, and plans to work on ADC after that, so there
>> won't be much duplication of effort.
>> Gedare
>> On Wed, Jun 3, 2015 at 10:48 AM, Andrew Harris <andrew.unit at gmail.com>
>> wrote:
>> > Hi,
>> >    I was curious to see when they started and what they're going to work
>> > on.
>> > I'm new to BSP development, but I have working drivers for I2C, GPIO and
>> > PWM
>> > (I believe possibly for the BBBlack only).  Right now they're not
>> > building
>> > in the normal BSP directory, but in my project directory.  So I probably
>> > have a chunk of work still to do to get them building in the way the BSP
>> > expects.  I'm hoping to get them released back to RTEMS, but I have to
>> > work
>> > through my employer's public release process first.  I was curious to
>> > see
>> > when the students were going to start and what they were going to work
>> > on.
>> > I see one of the students would be working on the network stack.  If the
>> > other student worked on the ADC and USB drivers before working on I2C
>> > and
>> > GPIO, maybe we could avoid some duplication of effort.  Just a
>> > suggestion.
>> > -andrew
>> > On Wed, Jun 3, 2015 at 9:11 AM, Joel Sherrill
>> > <joel.sherrill at oarcorp.com>
>> > wrote:
>> >> On June 3, 2015 9:07:23 AM EDT, Anand Krishnan <anandkp92 at gmail.com>
>> >> wrote:
>> >> >Hi,
>> >> >The students have already started the  work. You can follow their
>> >> >progress at : https://devel.rtems.org/wiki/GSoC/2015
>> >> They are collectively adding device drivers to the BB BSP which already
>> >> supported all variants.
>> >> Andrew. What drivers are you must interested in?
>> >> >Thanks!
>> >> >Anand
>> >> >On Wed, Jun 3, 2015 at 6:17 PM, Andrew Harris <andrew.unit at gmail.com>
>> >> >wrote:
>> >> >Hi,
>> >> >I'm curious when the GSOC students will be starting work on the
>> >> >beaglebone BSP.  Does anyone have an idea?
>> >> >thanks,
>> >> >-andrew
>> >> >_______________________________________________
>> >> >users mailing list
>> >> >users at rtems.org
>> >> >http://lists.rtems.org/mailman/listinfo/users
>> >> --joel
>> > users mailing list
>> > users at rtems.org
