Best way to update RTEMS?
Tue Jun 9 17:49:45 UTC 2015
On Tue, Jun 9, 2015 at 1:23 PM, Mr. Andrei Chichak <groups at chichak.ca> wrote:
> If it helps at all, due to this thread, I decided to do a git pull and update RTEMS.
> Of course, the pull only brings in the source that has changed, it doesn’t recompile everything. So I typed make and broke everything, doh! Just doing a make is not adequate.
> From my crap memory and a couple of scripts, I managed to blow away all of my tools and the source. I started again at source-builder, but that only gave me the tools. As a user, I figure that that should actually be called tool-builder, but I digress.
> Eventually I did a git clone to get me back to where I should have started, then used my script that looks like:
> ./bootstrap -c
> ./bootstrap
> configure  (bunch of stuff)
> make (other stuff)
> and I was back on the air.
> So, I went onto a different system, did a git pull and the bootstrap/configure/make commands from above and it worked nicely.
> My questions are: When SHOULD I be doing git pulls? How do we find out when the tools and source have incompatible changes and need to run tool-builder?
Ideally, we will start to release RTEMS more frequently (I'd guess
annually), and you would only care to update in case you need some new
features or bug fixes. The lengthy, rolling development of the 4.11
version is sub-optimal.
> Andrei
>> On 2015-June-09, at 10:55 AM, Wu, Mark H. <Mark.H.Wu at disney.com> wrote:
>> Interesting. I'll try those next time. But I did follow the steps below (bootstrap, configure, make), and it didn't resolve the problem. I had to start with a clean directory to get it to work again.
>> -----Original Message-----
>> From: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
>> Sent: Monday, June 08, 2015 22:11
>> To: Gedare Bloom
>> Cc: Wu, Mark H.; users at rtems.org
>> Subject: Re: Best way to update RTEMS?
>> Hello,
>> in most cases it is enough to run configure with the --enable-mainainer-mode option and then do a "make preinstall" in an existing build tree.  If you get strange errors, then do the below steps.
>> ----- Gedare Bloom <gedare at rtems.org> schrieb:
>>> After pulling, it is a good idea to:
>>> 1. re-run bootstrap, in case any of the autoconf input files have
>>> changed (Makefile.am, preinstall.am, configure.ac).
>>> 2. re-run configure, in case bootstrap changed any of the autoconf
>>> output files (configure, Makefile.in)
>>> 3. re-run make, in case configure changed any of its outputs (Makefile)
>>> The cleanest thing to do is to delete your build directory--where you
>>> previously have run configure and make, which should not be the same
>>> as your source (rtems.git) directory.
>>> Gedare
>>> On Mon, Jun 8, 2015 at 3:25 PM, Wu, Mark H. <Mark.H.Wu at disney.com> wrote:
>>>> I started with a fresh directory, ran configure and make, and it built fine. Is configure supposed to update the directory when a new pull is done, or is it make that's supposed to update things?
>>>> From: Chris Johns [mailto:chrisj at rtems.org]
>>>> Sent: Friday, June 05, 2015 18:48
>>>> To: Wu, Mark H.; users at rtems.org
>>>> On 6/06/2015 11:11 am, Wu, Mark H. wrote:
>>>>> I downloaded RTEMS from the git repo a few weeks ago, and have things at a stable point (still working on getting a few things to work, like networking). I decided to update from the git repo, and can't seem to get it rebuilt correctly. What are the correct steps to update my libraries after pulling down from the repo?
>>>> How did you update RTEMS ? I normally do a 'git pull'.
>>>>> What I have done so far:
>>>>> 1. Run ./bootstrap within the RTEMS directory
>>>>> 2. Re-run configure from within my installation directory
>>>>> 3. Re-run make from within my installation directory
>>>> Just to clear up any misunderstanding, we use the term 'source'
>>>> directory for the location of the RTEMS source code we are building. We
>>>> term the 'installation' directory the locate the files the 'make
>>>> install' process installs RTEMS to, ie the configure's -prefix path.
>>>>> This is where it fails - I have a compilation error. The files within my installation directory don't quite match the ones in the RTEMS directory.
>>>>> I believe that these are the same steps I performed upon initial installation (the same steps in the quick start). Do they not work for updating? Is there another (better) procedure for updating RTEMS?
>>>> What is your configure command line ?
>>>> What is the error ?
>>>> The error all depends on the point you took your initial build from.
>>>> There was a change in newlib that effected the RTEMS kernel source and
>>>> that requires an RSB update and a rebuild of your tools.
>>>> Please note, this type of change does not happen on releases and once
>>>> 4.11 is released you will experience a stable environment.
>>>> Chris
>>>> _______________________________________________
>>>> users mailing list
>>>> users at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/users
>>> users mailing list
>>> users at rtems.org
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> users mailing list
>> users at rtems.org
> users mailing list
> users at rtems.org
