attaching an interrupt in beaglebone bsp
Angelo Fraietta
newsgroups at smartcontroller.com.au
Tue Jun 16 22:38:10 UTC 2015
Which is the config file that I need to change?
On Tue, Jun 16, 2015 at 5:36 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 16/06/2015 4:14 pm, Angelo Fraietta wrote:
> /home/angelo/development/rtems/sources/rtems-source-builder/rtems/build/qemu-ac0bfdb9c310276521e5b089d7f36c1f610ca60b-i686-linux-gnu-1/qemu-ac0bfdb9c310276521e5b089d7f36c1f610ca60b/hw/misc/twl4030.c:71:
> > error: redefinition of typedef 'TWL4030NodeState'
> /home/angelo/development/rtems/sources/rtems-source-builder/rtems/build/qemu-ac0bfdb9c310276521e5b089d7f36c1f610ca60b-i686-linux-gnu-1/qemu-ac0bfdb9c310276521e5b089d7f36c1f610ca60b/hw/misc/twl4030.c:51:
> > note: previous declaration of 'TWL4030NodeState' was here
> Something is broken in this qemu.
> It might be worth looking at a later version. The head of the linaro
> repo is e571600c4a260d3072abbe7ecf2013e48e82bea7.
> I suggest you locate the config file in Ben's version and update it and
> see what happens.
> Qemu is a complex package and build it from source on a wide number of
> hosts is demanding so please be patient. What ever you can try and feed
> back to Ben would be most welcome.
> Chris
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20150617/3f9bd1f0/attachment-0001.html>
