RTEMS on Intel Core 2 Duo
Fri Jun 19 20:37:37 UTC 2015
On June 19, 2015 3:33:50 PM CDT, Wendell Silva <silvawp at gmail.com> wrote:
>Hello,
>What is the option (or the switch of the configure script or, even
>better, the rtems source builder option) to compile RTEMS for Intel
>Core 2 Duo?
>Is pc686 bsp compatible with Intel Core 2 Duo?
Any variant will run but the SSE one is likely the best match. This is also the minimum (and only) variant high enough architecturally to support SMP.
Also there is a ticket for an update that needs to the SMP synchronization algorithm during a context switch.
>Thanks,
>--Wendell
--joel
