"error: environment PATH invalid path: ." with Building a Tools set with RTEMS
Alvin Dulcan Alvin.Dulcan at sslmda.com
Mon Jun 29 21:16:46 UTC 2015
Thanks,
That was it.
Alvin
-----Original Message-----
From: Karel Gardas [mailto:karel.gardas at centrum.cz]
Sent: Monday, June 29, 2015 12:23 PM
To: Alvin Dulcan
Cc: users at rtems.org
Subject: Re: "error: environment PATH invalid path: ." with Building a Tools set with RTEMS
Yes, just remove dot (current dir) from your PATH...
Karel
On 06/29/15 09:06 PM, Alvin Dulcan wrote:
> When I try to do the first step of a quick start on
> https://devel.rtems.org/wiki/Developer/Tools/RSB:
> $ cd
> $ mkdir -p development/rtems/rsb
> $ cd development/rtems/rsb
> $ git clone git://git.rtems.org/rtems-source-builder.git
> $ cd rtems-source-builder
> $ cd rtems
> $ ../source-builder/sb-set-builder
> --prefix=$HOME/development/rtems/4.11
> 4.11/rtems-sparc
> I get:
> cat rsb-log-20150629-184804.txt
> RTEMS Source Builder - Set Builder, v0.5.0
> Command Line: ../source-builder/sb-set-builder
> --prefix=/home/itacs/development/rtems/4.11 4.11/rtems-sparc
> Python: 2.6.6 (r266:84292, Jun 18 2012, 14:18:47) [GCC 4.4.6 20110731
> (Red Hat 4.4.6-3)]
> I installed all of the packages for CENTOS (release 6.2)
> Thanks,
> Alvin
> -- This message (including any attachments) may contain confidential
> information intended for a specific individual and purpose. If you are
> not the intended recipient, you should delete this message and any
> attachments.
> users mailing list
> users at rtems.org
 This message (including any attachments) may contain confidential information intended for a specific individual and purpose. If you are not the intended recipient, you should delete this message and any attachments.
