SOLVED Re: Problem with rtems_event_send crashing from interrupt routine
Mr. Andrei Chichak groups at chichak.ca
Tue Jun 30 13:51:44 UTC 2015
Could the maskability be checked on the call to the RTEMS facilities?  If we are running as an NMI and must not use RTEMS facilities, perhaps a failure return code instead of RTEMS_SUCCESSFUL on the call.
Andrei
