SOLVED Re: Problem with rtems_event_send crashing from interrupt routine
Tue Jun 30 13:53:07 UTC 2015
On 30/06/15 15:51, Mr. Andrei Chichak wrote:
> Could the maskability be checked on the call to the RTEMS facilities?  If we are running as an NMI and must not use RTEMS facilities, perhaps a failure return code instead of RTEMS_SUCCESSFUL on the call.
The NMI stuff is currently invisible to RTEMS, so there is no API to
work with (except architecture/BSP specific functions).
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
