Beaglebone Bootloader
Angelo Fraietta newsgroups at smartcontroller.com.au
Tue Jun 23 22:40:08 UTC 2015
My image is not loading.
U-Boot SPL 2014.04-00014-g47880f5 (Apr 22 2014 - 13:23:54)
reading args
spl_load_image_fat_os: error reading image args, err - -1
reading u-boot.img
reading u-boot.img
U-Boot 2014.04-00014-g47880f5 (Apr 22 2014 - 13:23:54)
I2C:   ready
DRAM:  512 MiB
NAND:  0 MiB
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
*** Warning - readenv() failed, using default environment
Net:   <ethaddr> not set. Validating first E-fuse MAC
cpsw, usb_ether
Hit any key to stop autoboot:  0
gpio: pin 53 (gpio 53) value is 1
Card did not respond to voltage select!
mmc0(part 0) is current device
gpio: pin 56 (gpio 56) value is 0
gpio: pin 55 (gpio 55) value is 0
gpio: pin 54 (gpio 54) value is 0
mmc1(part 0) is current device
gpio: pin 54 (gpio 54) value is 1
SD/MMC found on device 1
reading uEnv.txt
426 bytes read in 4 ms (103.5 KiB/s)
gpio: pin 55 (gpio 55) value is 1
Loaded environment from uEnv.txt
Importing environment from mmc ...
Checking if uenvcmd is set ...
gpio: pin 56 (gpio 56) value is 1
Running uenvcmd ...
cpsw Waiting for PHY auto negotiation to complete. done
link up on port 0, speed 100, full duplex
Using cpsw device
TFTP from server 192.168.0.25; our IP address is 192.168.0.53
Filename '/hello'.
Load address: 0x81000000
Loading: #################################################################
         4.9 MiB/s
done
Bytes transferred = 33554432 (2000000 hex)
Wrong Image Format for bootm command
ERROR: can't get kernel image!
uenvcmd was not defined in uEnv.txt ...
Booting from nand ...
no devices available
Bad Linux ARM zImage magic!
U-Boot#
It would not load the image. So I think my image is bad. Can someone email
me the image for the hello example for beagle already
I modified the uEnv.txt on the device. Now, however, I have a beagle that
is in the uBoot menu and I can't change the eUenv,txt because it will not
how up as a drive because it is not booted into linux.
How do I get back to beagle linux from u-boot prompt?
Thanks
On Tue, Jun 23, 2015 at 6:44 PM, Cláudio Silva <claudiodcsilva at gmail.com>
wrote:
> Hello Angelo,
> I am using the following script snippet to generate a u-boot bootable
> image from an RTEMS .exe:
> https://gist.github.com/cdcs/0c789e9aae9e79200da5
> It essentially follows the steps described in Ben's README.
> If you are using application=/TICKER in the script, it will try to load
> something called TICKER from the tftp root (without any extension).
> Did you try with the u-boot that comes preloaded in the BBB?
> You can just try boot the linux version provided in the BBB's emmc and
> then change the uEnv.txt ("/boot/uboot/uEnv.txt") to your tftp version of
> uEnv. You shouldn't need the sdcard.
> Best Regards,
> Cláudio
> On Tue, Jun 23, 2015 at 5:59 AM Angelo Fraietta <
> newsgroups at smartcontroller.com.au> wrote:
>> If it is any help. this is the configuration on my SDCard that loads
>> debian linux from SDCard.
>> ##Video: Uncomment to override:
>> ##see:
>> https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tree/Documentation/fb/modedb.txt
>> #kms_force_mode=video=HDMI-A-1:1024x768 at 60e
>> ##Enable systemd
>> systemd=quiet init=/lib/systemd/systemd
>> ##BeagleBone Cape Overrides
>> ##BeagleBone Black:
>> ##Disable HDMI/eMMC
>> #optargs=capemgr.disable_partno=BB-BONELT-HDMI,BB-BONELT-HDMIN,BB-BONE-EMMC-2G
>> ##Disable HDMI
>> ##WIP: v3.13+ capes..
>> #cape=lcd4-01
>> #cape=
>> ##note: the eMMC flasher script relies on the next line
>> mmcroot=UUID=8f529ad7-82d1-4d8e-91dc-31e9e2080813 ro
>> mmcrootfstype=ext4 rootwait fixrtc
>> ##These are needed to be compliant with Angstrom's 2013.06.20 u-boot.
>> console=ttyO0,115200n8
>> kernel_file=zImage
>> initrd_file=initrd.img
>> loadaddr=0x82000000
>> initrd_addr=0x88080000
>> fdtaddr=0x88000000
>> initrd_high=0xffffffff
>> fdt_high=0xffffffff
>> loadkernel=load mmc ${mmcdev}:${mmcpart} ${loadaddr} ${kernel_file}
>> loadinitrd=load mmc ${mmcdev}:${mmcpart} ${initrd_addr} ${initrd_file};
>> setenv initrd_size ${filesize}
>> loadfdt=load mmc ${mmcdev}:${mmcpart} ${fdtaddr} /dtbs/${fdtfile}
>> loadfiles=run loadkernel; run loadinitrd; run loadfdt
>> mmcargs=setenv bootargs console=tty0 console=${console} ${optargs}
>> ${kms_force_mode} root=${mmcroot} rootfstype=${mmcrootfstype} ${systemd}
>> uenvcmd=run loadfiles; run mmcargs; bootz ${loadaddr}
>> ${initrd_addr}:${initrd_size} ${fdtaddr}
>> On Tue, Jun 23, 2015 at 12:59 PM, Angelo Fraietta <
>>> I can see I missed a step from Ben's tutorial where it creates the image
>>> file.
>>> I copied the image to tftp and it did not work
>>> I also tried doing out of Bens tutorial the
>>> dd if=bone_hello.exe-sdcard.img of=/dev/mmcblk0 bs=4096
>>> However, nothing was displayed on my monitor and the three LEDS lit,
>>> followed by the light on ethernet port. It did this about three times and
>>> then booted into normal BBB linux. It looked to me like it was resetting,
>>> however, can't be sure.
>>> Is someone able to email me a working image for BBB so I can see it that
>>> will boot.
>>> Thanks
>>> On Tue, Jun 23, 2015 at 8:46 AM, Angelo Fraietta <
>>>> Does not boot.
>>>> I have u-boot on the SD card. I know it is being called because if I
>>>> disconnect the ethernet, it freezes and does not boot. If I remove SDcard
>>>> and remove ethernet, it boots normally
>>>> I have tftp on 192.168.0.25
>>>> My configuration is exactly this
>>>> ### BBB : Configuration
>>>> ipaddr=192.168.0.53
>>>> serverip=192.168.0.25
>>>> netmask=255.255.255.0
>>>> ### XKY-OS : Configuration
>>>> baseaddr=0x81000000
>>>> application=/TICKER
>>>> ### Boot BBB from network
>>>> nfsargs=setenv bootargs console=${console} root=/dev/nfs
>>>> nfsroot=${serverip}:${rootpath} rw
>>>> ip=${ipaddr}:${serverip}:${serverip}:${netmask}::eth0:off
>>>> xkyboot=run nfsargs; tftp ${baseaddr} ${application}; bootm ${baseaddr}
>>>> uenvcmd=run xkyboot
>>>> I have copied ticker.exe to root folder
>>>> I tried
>>>> application=/TICKER
>>>> application=/ticker.exe
>>>> application=/TICKER.EXE
>>>> Just boots into normal regardless of what I do (except removing
>>>> ethernet with SDCard in). Looking at U-boot in display looks the same as
>>>> though three was no SDcard. How can I freeze screen to read what it all
>>>> says?
>>>> I tested my tftp server like this
>>>> http://www.gunnalag.com/2013/08/05/how-to-test-tftp-server-from-a-client-system-in-windows/
>>>> I did
>>>> tftp -i 1923.168.0.25 get ticker.exe
>>>> And it worked fine
>>>> So if I am using ticker.exe, what should application=/TICKER be? Is it
>>>> case sensitive? Does it need .exe at the end? Am I supposed to be using
>>>> ticker.exe?
>>>> Can someone send me an exe that does load in BBB so I can see if it is
>>>> that loads.
>>>> Also, I followed tutorial for installing U-boot on an SDCard which
>>>> boots linux from SDCard and that works
>>>> http://www.armhf.com/boards/beaglebone-black/bbb-sd-install/
>>>> Any suggestions would be great
>>>> Thanks
>>>> On Mon, Jun 22, 2015 at 6:39 PM, Cláudio Silva <
>>>> claudiodcsilva at gmail.com> wrote:
>>>>> Hi Angelo,
>>>>> xkyboot is just a command name that is executed by uenvcmd; you can
>>>>> name whatever you want. "XKYAPP2" is the executable name. It should placed
>>>>> on the tftp server's root, or otherwise you need to provide the full path
>>>>> to it.
>>>>> Is your tftp server working correctly? Try to test from a tftp client
>>>>> on Linux.
>>>>> Best Regards,
>>>>> Cláudio
>>>>> On Mon, Jun 22, 2015 at 6:51 AM Angelo Fraietta <
>>>>>> I am using BBB also
>>>>>> I have had a look at what you have provided
>>>>>> are XKYAPP2 and xkyboot  your app names?
>>>>>> Lets say I wanted to boot ticker from tftp server (assume my tftp
>>>>>> server has same ip address as yours)
>>>>>> I have copied
>>>>>> development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack/testsuites/samples/ticker/ticker.exe
>>>>>> to the root of my tftp server
>>>>>> I am assuming this is entire uEnv.txt What should it look like (I
>>>>>> have provided whole of your file here). Thanks
>>>>>> ipaddr=192.168.0.202
>>>>>> baseaddr=0x81000000
>>>>>> application=/XKYAPP2
>>>>>> nfsargs=setenv bootargs console=${console} root=/dev/nfs nfsroot=${serverip}:${rootpath} rw ip=${ipaddr}:${serverip}:${serverip}:${netmask}::eth0:off
>>>>>> uenvcmd=run xkyboot
>>>>>> On Fri, Jun 19, 2015 at 6:14 PM, Cláudio Silva <
>>>>>>> You should be able to boot RTEMS through TFTP. At least I do it in
>>>>>>> the BBB, I assume the white version should work as well. You just have to
>>>>>>> change uboot configuration and setup a tftp server.
>>>>>>> My current uboot configuration is the following:
>>>>>>> https://gist.github.com/cdcs/76c4dd49c2d574bd68cc
>>>>>>> Cláudio
>>>>>>> On Fri, Jun 19, 2015 at 5:57 AM Chris Johns <chrisj at rtems.org>
>>>>>>> wrote:
>>>>>>>> On 19/06/2015 1:56 pm, Angelo Fraietta wrote:
>>>>>>>> > Those links I posted -- do any of them work with RTEMS?
>>>>>>>> I do not know. I have no interested uboot. Maybe someone else knows.
>>>>>>>> Chris
>>>>>>>> _______________________________________________
>>>>>>>> users mailing list
>>>>>>>> users at rtems.org
>>>>>>>> http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20150624/627a6767/attachment-0002.html>
