Beaglebone Bootloader
Cláudio Silva claudiodcsilva at gmail.com
Tue Jun 23 08:44:29 UTC 2015
Hello Angelo,
I am using the following script snippet to generate a u-boot bootable image
from an RTEMS .exe:
https://gist.github.com/cdcs/0c789e9aae9e79200da5
It essentially follows the steps described in Ben's README.
If you are using application=/TICKER in the script, it will try to load
something called TICKER from the tftp root (without any extension).
Did you try with the u-boot that comes preloaded in the BBB?
You can just try boot the linux version provided in the BBB's emmc and then
change the uEnv.txt ("/boot/uboot/uEnv.txt") to your tftp version of uEnv.
You shouldn't need the sdcard.
Best Regards,
Cláudio
On Tue, Jun 23, 2015 at 5:59 AM Angelo Fraietta <
newsgroups at smartcontroller.com.au> wrote:
> If it is any help. this is the configuration on my SDCard that loads
> debian linux from SDCard.
> ##Video: Uncomment to override:
> ##see:
> https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tree/Documentation/fb/modedb.txt
> #kms_force_mode=video=HDMI-A-1:1024x768 at 60e
> ##Enable systemd
> systemd=quiet init=/lib/systemd/systemd
> ##BeagleBone Cape Overrides
> ##BeagleBone Black:
> ##Disable HDMI/eMMC
> #optargs=capemgr.disable_partno=BB-BONELT-HDMI,BB-BONELT-HDMIN,BB-BONE-EMMC-2G
> ##Disable HDMI
> ##WIP: v3.13+ capes..
> #cape=lcd4-01
> #cape=
> ##note: the eMMC flasher script relies on the next line
> mmcroot=UUID=8f529ad7-82d1-4d8e-91dc-31e9e2080813 ro
> mmcrootfstype=ext4 rootwait fixrtc
> ##These are needed to be compliant with Angstrom's 2013.06.20 u-boot.
> console=ttyO0,115200n8
> kernel_file=zImage
> initrd_file=initrd.img
> loadaddr=0x82000000
> initrd_addr=0x88080000
> fdtaddr=0x88000000
> initrd_high=0xffffffff
> fdt_high=0xffffffff
> loadkernel=load mmc ${mmcdev}:${mmcpart} ${loadaddr} ${kernel_file}
> loadinitrd=load mmc ${mmcdev}:${mmcpart} ${initrd_addr} ${initrd_file};
> setenv initrd_size ${filesize}
> loadfdt=load mmc ${mmcdev}:${mmcpart} ${fdtaddr} /dtbs/${fdtfile}
> loadfiles=run loadkernel; run loadinitrd; run loadfdt
> mmcargs=setenv bootargs console=tty0 console=${console} ${optargs}
> ${kms_force_mode} root=${mmcroot} rootfstype=${mmcrootfstype} ${systemd}
> uenvcmd=run loadfiles; run mmcargs; bootz ${loadaddr}
> ${initrd_addr}:${initrd_size} ${fdtaddr}
> On Tue, Jun 23, 2015 at 12:59 PM, Angelo Fraietta <
>> I can see I missed a step from Ben's tutorial where it creates the image
>> file.
>> I copied the image to tftp and it did not work
>> I also tried doing out of Bens tutorial the
>> dd if=bone_hello.exe-sdcard.img of=/dev/mmcblk0 bs=4096
>> However, nothing was displayed on my monitor and the three LEDS lit,
>> followed by the light on ethernet port. It did this about three times and
>> then booted into normal BBB linux. It looked to me like it was resetting,
>> however, can't be sure.
>> Is someone able to email me a working image for BBB so I can see it that
>> will boot.
>> Thanks
>> On Tue, Jun 23, 2015 at 8:46 AM, Angelo Fraietta <
>>> Does not boot.
>>> I have u-boot on the SD card. I know it is being called because if I
>>> disconnect the ethernet, it freezes and does not boot. If I remove SDcard
>>> and remove ethernet, it boots normally
>>> I have tftp on 192.168.0.25
>>> My configuration is exactly this
>>> ### BBB : Configuration
>>> ipaddr=192.168.0.53
>>> serverip=192.168.0.25
>>> netmask=255.255.255.0
>>> ### XKY-OS : Configuration
>>> baseaddr=0x81000000
>>> application=/TICKER
>>> ### Boot BBB from network
>>> nfsargs=setenv bootargs console=${console} root=/dev/nfs
>>> nfsroot=${serverip}:${rootpath} rw
>>> ip=${ipaddr}:${serverip}:${serverip}:${netmask}::eth0:off
>>> xkyboot=run nfsargs; tftp ${baseaddr} ${application}; bootm ${baseaddr}
>>> uenvcmd=run xkyboot
>>> I have copied ticker.exe to root folder
>>> I tried
>>> application=/TICKER
>>> application=/ticker.exe
>>> application=/TICKER.EXE
>>> Just boots into normal regardless of what I do (except removing ethernet
>>> with SDCard in). Looking at U-boot in display looks the same as though
>>> three was no SDcard. How can I freeze screen to read what it all says?
>>> I tested my tftp server like this
>>> http://www.gunnalag.com/2013/08/05/how-to-test-tftp-server-from-a-client-system-in-windows/
>>> I did
>>> tftp -i 1923.168.0.25 get ticker.exe
>>> And it worked fine
>>> So if I am using ticker.exe, what should application=/TICKER be? Is it
>>> case sensitive? Does it need .exe at the end? Am I supposed to be using
>>> ticker.exe?
>>> Can someone send me an exe that does load in BBB so I can see if it is
>>> that loads.
>>> Also, I followed tutorial for installing U-boot on an SDCard which boots
>>> linux from SDCard and that works
>>> http://www.armhf.com/boards/beaglebone-black/bbb-sd-install/
>>> Any suggestions would be great
>>> Thanks
>>> On Mon, Jun 22, 2015 at 6:39 PM, Cláudio Silva <claudiodcsilva at gmail.com
>>> > wrote:
>>>> Hi Angelo,
>>>> xkyboot is just a command name that is executed by uenvcmd; you can
>>>> name whatever you want. "XKYAPP2" is the executable name. It should placed
>>>> on the tftp server's root, or otherwise you need to provide the full path
>>>> to it.
>>>> Is your tftp server working correctly? Try to test from a tftp client
>>>> on Linux.
>>>> Best Regards,
>>>> Cláudio
>>>> On Mon, Jun 22, 2015 at 6:51 AM Angelo Fraietta <
>>>>> I am using BBB also
>>>>> I have had a look at what you have provided
>>>>> are XKYAPP2 and xkyboot  your app names?
>>>>> Lets say I wanted to boot ticker from tftp server (assume my tftp
>>>>> server has same ip address as yours)
>>>>> I have copied
>>>>> development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack/testsuites/samples/ticker/ticker.exe
>>>>> to the root of my tftp server
>>>>> I am assuming this is entire uEnv.txt What should it look like (I have
>>>>> provided whole of your file here). Thanks
>>>>> ipaddr=192.168.0.202
>>>>> baseaddr=0x81000000
>>>>> application=/XKYAPP2
>>>>> nfsargs=setenv bootargs console=${console} root=/dev/nfs nfsroot=${serverip}:${rootpath} rw ip=${ipaddr}:${serverip}:${serverip}:${netmask}::eth0:off
>>>>> uenvcmd=run xkyboot
>>>>> On Fri, Jun 19, 2015 at 6:14 PM, Cláudio Silva <
>>>>> claudiodcsilva at gmail.com> wrote:
>>>>>> You should be able to boot RTEMS through TFTP. At least I do it in
>>>>>> the BBB, I assume the white version should work as well. You just have to
>>>>>> change uboot configuration and setup a tftp server.
>>>>>> My current uboot configuration is the following:
>>>>>> https://gist.github.com/cdcs/76c4dd49c2d574bd68cc
>>>>>> Cláudio
>>>>>> On Fri, Jun 19, 2015 at 5:57 AM Chris Johns <chrisj at rtems.org> wrote:
>>>>>>> On 19/06/2015 1:56 pm, Angelo Fraietta wrote:
>>>>>>> > Those links I posted -- do any of them work with RTEMS?
>>>>>>> I do not know. I have no interested uboot. Maybe someone else knows.
>>>>>>> Chris
>>>>>>> _______________________________________________
>>>>>>> users mailing list
>>>>>>> users at rtems.org
>>>>>>> http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20150623/10650355/attachment-0002.html>
