How to integrate the EMAC with FreeBSD on RTEMS?
黄喜
huangxi_hans at 163.com
Thu Mar 26 09:20:51 UTC 2015
Hi,
I want to running TCP/IP application in AM335x, Does have a detail guide tell how to integrate the EMAC driver with FreeBSD? Thanks.
At 2015-03-26 11:00:49, users-request at rtems.org wrote:
>Send users mailing list submissions to
> users at rtems.org
>To subscribe or unsubscribe via the World Wide Web, visit
>or, via email, send a message with subject or body 'help' to
>You can reach the person managing the list at
> users-owner at rtems.org
>When replying, please edit your Subject line so it is more specific
>than "Re: Contents of users digest..."
>Today's Topics:
> 1. Re: Questions about the implementation of RMS on rtems
> (yuanbin zhou)
> 2. Re: Questions about the implementation of RMS on rtems
> (Gedare Bloom)
> 3. Re: GSOC and ESA SOCIS (Gedare Bloom)
> 4. Re: Questions about the implementation of RMS on rtems
> (Matt Wette)
> 5. Re: Questions about the implementation of RMS on rtems
> (Anand Krishnan)
>Message: 1
>Date: Wed, 25 Mar 2015 20:00:23 +0800
>From: yuanbin zhou <hduffddybz at gmail.com>
>To: Joel Sherrill <joel.sherrill at oarcorp.com>
>Cc: "users at rtems.org" <users at rtems.org>, Yifan WU <yfwu.cn at gmail.com>
>Subject: Re: Questions about the implementation of RMS on rtems
>Message-ID:
> <CAAocCaJK3aUCrxYBdiw5yVyYMa-cxT53Fs-gvK=ZAge32QpNCA at mail.gmail.com>
>Content-Type: text/plain; charset="utf-8"
>Sorry for late reply because of paper reading, taking courses and
> unimportant things.
>>2. How to use the processor utilization rule and first deadline rule to
>> >guarantee as more as possible tasks to run since the execution time of
>> >each tasks cannot accurately know before the task run?
>> This is in the users manual and in the original 1973 JACM paper referenced.
>> It also includes the assumptions about the underlying OS and environment.
>Recently I read the paper written by C.L.LIU(Scheduling Algorithms for
>Multiprogramming in a Hard-Real-Time Environment), this paper talks about
>the algorithm of RM Scheduling and the proof of it.But now what I am more
>concerned about is how to apply this rule to the analysis of real-time
>system.Maybe the analysis of the schedulability of this this system should
>be done by off-line tools before system start up.But the analysis of
>worse-case execution time may not correct which may result in execution
>overrun,so some papers put forward some resource reservation mechanisms to
>solve this problem.So confused about the paper reading, so I want to know
> how to handle this situation in "rtems"since that I cannot figure out any
>information from the user manual.
>> >3. Obey the rate monotonic scheduling algorithm, we can easily set the
>> >priority of every periodic tasks. But in many applications, it consists
>> >both periodic and aperiodic tasks(such as irregular interrupt which is
>> >also essential task), so how to handle the priority setting for this
>> >situation or just set the irregular task's priority by manual?
>> You need to do some academic paper research. There are a number of papers
>> describing how to address various task patterns
>I read some papers about the handle of periodic tasks and aperiodic tasks.There
>existed two kinds of method to solve this problem.
>First:the system can schedule the aperiodic tasks by periodic server which
>allocates a certain amount of budget for aperiodic execution in every
>period time.
> second:there is no benefit for the periodic tasks to complete their tasks
>much before their deadlines. So when the aperiodic task coming, it steals
>the available slack from the periodic tasks and execute it as soon as
>possible.
>So can give more detail about the implementation of this in rtems which I
>cannot find anything from the user manual and it is really complicated to
>find the corresponding source file for all the source files located in only
>one directory!
>-------------- next part --------------
>An HTML attachment was scrubbed...
>URL: <http://lists.rtems.org/pipermail/users/attachments/20150325/d7fc8cfa/attachment-0001.html>
>Message: 2
>Date: Wed, 25 Mar 2015 10:11:23 -0400
>From: Gedare Bloom <gedare at rtems.org>
>To: yuanbin zhou <hduffddybz at gmail.com>
>Message-ID:
> <CAC82fA0Lomtt5uauWpoNhycs_mQRH2VWJztAbYgDOsCM1czf9Q at mail.gmail.com>
>Content-Type: text/plain; charset=UTF-8
>You might like to try reading a text book on real-time systems, such
>as Jane Liu's book. If you have accurate WCET measurements then RMS
>works by assigning periods to tasks, computing U < 0.69 (or whatever),
>and assigning priorites inversely to periods. Then you have to ensure
>that the periods are enforced. RTEMS has mechanisms for creating the
>periodic timers and to return a status code in case of an overrun. It
>is up to the application to detect an overrun and account for it in
>this case.
>Gedare
>On Wed, Mar 25, 2015 at 8:00 AM, yuanbin zhou <hduffddybz at gmail.com> wrote:
>> unimportant things.
>>> referenced.
>> tasks.There existed two kinds of method to solve this problem.
>> allocates a certain amount of budget for aperiodic execution in every period
>> time.
>> possible.
>> one directory!
>> users mailing list
>> users at rtems.org
>Message: 3
>Date: Wed, 25 Mar 2015 12:32:17 -0400
>From: Gedare Bloom <gedare at gwu.edu>
>Cc: "users at rtems.org" <users at rtems.org>, "devel at rtems.org"
> <devel at rtems.org>
>Subject: Re: GSOC and ESA SOCIS
>Message-ID:
> <CAC82fA2wjgLRHSD=jKep2j7JZ1av1=ZTj59gH9qinprkp815-Q at mail.gmail.com>
>P.S. mentors feel free to sign-up for GSoC. We have lots of
>interesting project proposals this year, does one catch your eye?
>https://devel.rtems.org/wiki/GSoC/2015
>On Wed, Mar 25, 2015 at 12:24 PM, Joel Sherrill
><joel.sherrill at oarcorp.com> wrote:
>> Hi
>> Only two days left to apply to GSOC.
>> The ESA SOCIS application period is now open. If you are qualified
>> based on their rules, please apply to both the SOCIS and GSOC.
>> Get those applications in!
>> Joel Sherrill, Ph.D. Director of Research & Development
>> joel.sherrill at OARcorp.com On-Line Applications Research
>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>> Support Available (256) 722-9985
>> devel mailing list
>> devel at rtems.org
>Message: 4
>Date: Wed, 25 Mar 2015 17:15:37 -0700
>From: Matt Wette <mwette at alumni.caltech.edu>
>To: users at rtems.org
>Message-ID: <D63DEED8-42C7-4FA3-ADD6-E0EAB9EFE455 at alumni.caltech.edu>
>Content-Type: text/plain; charset=us-ascii
>If you are interested in analysis of RM scheduling under different conditions you might be interested in the following book:
>A Practitioner's Handbook for Real-Time Analysis: Guide to Rate Monotonic Analysis for Real-Time Systems
>Message: 5
>Date: Thu, 26 Mar 2015 08:30:25 +0530
>From: Anand Krishnan <anandkp92 at gmail.com>
>Message-ID:
> <CAG-ttNtU_6AcvdPhOp5WUnJjg3Bnow=GGgAa3HnKJZfNPGmZBQ at mail.gmail.com>
>I am implementing the RM scheduler in C. Not how it is implemented in a
>system, but as a standalone C program: you give the input - #tasks and the
>WCET and period for each task and it schedules it.
>I've chosen the granularity of CPU clock to be 1sec.
>Currently, I assume the task set to be schedulable. The program just
>presents an Gantt Chart
>I need to add schedulability test and try reduce the CPU clock guarantee
>and implement it.
>I'm not sure if it helps you much, but you could go through it.
>regards,
>Anand
>On Wed, Mar 25, 2015 at 5:30 PM, yuanbin zhou <hduffddybz at gmail.com> wrote:
>> unimportant things.
>>> referenced.
>> which allocates a certain amount of budget for aperiodic execution in every
>> period time.
>> tasks much before their deadlines. So when the aperiodic task coming, it
>> steals the available slack from the periodic tasks and execute it as soon
>> as possible.
>> only one directory!
>> users mailing list
>> users at rtems.org
>URL: <http://lists.rtems.org/pipermail/users/attachments/20150326/98e08c02/attachment.html>
>3
>4 1
>5 2
>20 5
>A non-text attachment was scrubbed...
>Type: text/x-csrc
>Desc: not available
>URL: <http://lists.rtems.org/pipermail/users/attachments/20150326/98e08c02/attachment.bin>
>Subject: Digest Footer
>users mailing list
>users at rtems.org
>End of users Digest, Vol 102, Issue 15
URL: <http://lists.rtems.org/pipermail/users/attachments/20150326/381b9543/attachment-0001.html>
