Build with RSB - I got lost.
Stanisław Grzeszczak stgrzeszczak at gmail.com
Thu Mar 26 14:29:37 UTC 2015
Hello,
I'm a newcomer to RTEMS. The GSoC/GettingStarted
<https://devel.rtems.org/wiki/GSoC/GettingStarted> and Quick_Start
<https://devel.rtems.org/wiki/TBR/UserManual/Quick_Start> pages led me to
the RSB. I've followed the RSB <https://docs.rtems.org/rsb/> instructions
and built the toolset and RTEMS using the --with-rtems option. Now, I
wanted to get back to the GSOC/GettingStarted and Quick_Start instructions.
Question 0: Should I still run the bootstrap, configure and make scripts,
or did the RSB run them?
Both tutorials mention testing the build by running a gdb session on a test
program. I tried to build  the "Hello" example with gcc; however,
sparc-rtems4.11-gcc is unable to find the necessary header files. I tried
sparc-rtems4.11-cpp -v and the include paths do not match the locations
where rtems.h, rtems/test.h and others can be found.
Q 1: Do the mismatched paths mean that the build went wrong? Or should I
just fix the paths by hand, or move the lib/include folders?
(Q 2: Should the examples have already been built along with everything
else?)
I'd appreciate any help regarding my questions. Should I include any
additional information?
Thank you,
Stanislaw
URL: <http://lists.rtems.org/pipermail/users/attachments/20150326/05972bb9/attachment.html>
