Build with RSB - I got lost.
Thu Mar 26 15:04:35 UTC 2015
On 03/26/2015 09:58 AM, Anand Krishnan wrote:
> On Thu, Mar 26, 2015 at 8:18 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
>     On March 26, 2015 9:45:29 AM CDT, Anand Krishnan
>     <anandkp92 at gmail.com <mailto:anandkp92 at gmail.com>> wrote:
>     >On Thu, Mar 26, 2015 at 8:07 PM, Joel Sherrill
>     >On 03/26/2015 09:29 AM, Stanisław Grzeszczak wrote:
>     >Q 1: Do the mismatched paths mean that the build went wrong? Or should
>     >I just fix the paths by hand, or move the lib/include folders?
>     >(Q 2: Should the examples have already been built along with
>     everything
>     >else?)
>     >If you configured and built RTEMS using configure, make, etc and
>     >configured with
>     >--enable-tests=samples, the executable was there and has symbolic
>     >information in it.
>     >I have no idea what you did. If you used a native gcc or tried to
>     >compile it by hand,
>     >then it didn't work.
>     >When I had tried, I had to change the path variable to the directory
>     >where RSB built the tool-set.
>     >This was the code for I had to use: export
>     >PATH=/home/development/rtems/4.11/bin:$PATH , before I ran bootstrap.
>     What is the contents of that bin directory?
>     Do "type autoconf" and make sure you are getting the one for RTEMS.
> The bin directory had all the tools created for sparc:
> sparc-rtems4.11-gcc, sparc-rtems4.11-gdb among others.
> It was created after I build the sparc tool-set.
Then when you are at the top of the rtems source tree,
./bootstrap should just run without trouble based on you putting
that directory at the head of your PATH.
Then.... something like this
$ cd ..
$ mkdir b-sis
$ cd b-sis
$ ../rtems/configure --target=sparc-rtems4.11 --enable-rtemsbsp=sis
... that should end with a message indicating sis is a BSP to be built ...
$ make
$ find . -name "*.exe"
... that should print a handful of executables..
$ sparc-rtems4.11-gdb `find . -name hello.exe`
.... gdb stuff ...
(gdb) tar sim
(gdb) load
(gdb) run
... output...
>     >-- Joel Sherrill
>     >Ask me about RTEMS: a free RTOS
>     >Support and Training Available
>     >_______________________________________________
>     >users mailing list
>     >users at rtems.org <mailto:users at rtems.org>
>     >http://lists.rtems.org/mailman/listinfo/users
>     --joel
-- Joel Sherrill
