SPARC Floating Point Support Changes
Fri May 8 13:48:44 UTC 2015
To clarify, are you asking if SPARC user applications are manipulating
the FSR in a function without saving it first and restoring it before
returning?
On Fri, May 8, 2015 at 2:48 AM, Sebastian Huber
> Hello,
> we work currently on an optimization for the SPARC floating point support.
> See also:
> https://devel.rtems.org/ticket/2270
> We implement alternative (1). The floating point status register (FSR) is
> volatile according to the SPARC ABI.
> https://lists.rtems.org/pipermail/devel/2015-May/011232.html
> We are not sure if this is honoured in the RTEMS applications in general.
> Are there known uses cases which treat the FSR in a thread specific
> non-volatile way? It would be beneficial to rely on a volatile only usage
> since this would lead to a much simpler floating point context save/restore
> code.
> users mailing list
> users at rtems.org
