What is the use of .rwbarrier section?
Ken Liao
ken.i18n at gmail.com
Wed May 27 15:58:44 UTC 2015
Dear all,
I'm using Beaglebone BSP and the hello world example binary generated
from 71600 bytes .text section to 1055088 bytes
after 'arm-rtems4.11-objcopy -S -O binary hello.exe hello.bin'.
I assume the issue is cause by .rwbarrier section.
arm-rtems4.11-readelf -e hello.ralf show:
Section Headers:
[Nr] Name Type Addr Off Size ES Flg Lk
Inf Al
[ 0] NULL 00000000 000000 000000 00 0
0 0
[ 1] .start PROGBITS 80000000 000094 000384 00 AX 0
0 4
* [ 2] .text PROGBITS 80000384 000418 0108a0 00 WAX 0
0 4*
[ 3] .init PROGBITS 80010c24 010cb8 000018 00 AX 0
0 4
[ 4] .fini PROGBITS 80010c3c 010cd0 000018 00 AX 0
0 4
[ 5] .rodata PROGBITS 80010c54 010ce8 000b0c 00 A 0
0 4
[ 6] .ARM.exidx ARM_EXIDX 80011760 0117f4 000008 00 AL 2
0 4
[ 7] .eh_frame PROGBITS 80011768 0117fc 000048 00 A 0
0 4
[ 8] .init_array INIT_ARRAY 800117b0 011844 000004 00 WA 0
0 4
[ 9] .fini_array FINI_ARRAY 800117b4 011848 000004 00 WA 0
0 4
[10] .jcr PROGBITS 800117b8 01184c 000004 00 WA 0
0 4
*[11] .rwbarrier NOBITS 800117bc 011850 0ee844 00 WA 0
0 1*
[12] .vector NOBITS 80100000 011850 001400 00 WA 0
0 1
[13] .data PROGBITS 80101400 011860 000570 00 WA 0
0 8
[14] .bss NOBITS 80101980 011dd0 001d90 00 WA 0
0 32
[15] .work NOBITS 80103710 011dd0 fafc8f0 00 WA 0
0 1
rtems/c/src/lib/libbsp/arm/beagle/startup/linkcmds.beagle:
bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ?
bsp_section_rwbarrier_align : 1M;
rtems/c/src/lib/libbsp/arm/shared/startup/linkcmds.base:
.rwbarrier : ALIGN_WITH_INPUT {
. = ALIGN (bsp_section_rwbarrier_align);
} > REGION_DATA AT > REGION_DATA
So, what's the role of .rwbarrier section? Can i remove the section?
Best regards,
Ken Liao
URL: <http://lists.rtems.org/pipermail/users/attachments/20150527/15286c5a/attachment.html>
