RTEMS ARM build fails, timespec2bintime
Ben Gras beng at shrike-systems.com
Thu May 28 12:59:11 UTC 2015
All,
I have rebased and pushed the new branch. I have verified the new
version builds & the bsp (mainline) works.
Thanks for your interest in the BSP, I hope it goes well.
On Tue, May 26, 2015 at 1:20 AM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On May 25, 2015 5:12:09 PM CDT, Robert Perez <robertperez67 at hotmail.com> wrote:
>>Thanks Joel, I trust you :-)
>>This could be a simple question but, how to I update the toolset ?
>>Since I just cloned from Ben Grass git yesterday with:
> Ahh.. You need his repo to get the qemu that does BB right. But he apparently hasn't rebased against the master at git.rtems.org.
>>git clone -b beagle https://github.com/bengras/rtems-source-builder.git
>>I'm looking for it, but a little help is very welcomed.
>>Thanks !
>>> Subject: Re: RTEMS ARM build fails, timespec2bintime
>>> From: joel.sherrill at oarcorp.com
>>> Date: Sun, 24 May 2015 21:51:37 -0500
>>> To: robertperez67 at hotmail.com; users at rtems.org
>>> On May 24, 2015 9:13:24 PM CDT, Robert Perez
>>> >Hi everyone, I'm trying to build RTEMS for the beaglebone using this
>>> >tutorial
>>>http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html
>>> >but when executing the make command some errors are appearing
>>regarding
>>> >the timespec2bintime function, seems not to be declared, also some
>>> >related structs are not recognized (please see the attachment)
>>> >I've seen in https://sourceware.org/ml/newlib/2015/msg00186.html and
>>> >https://devel.rtems.org/ticket/2271 changes that could be related to
>>> >this error as I understand, but I'm new with RTEMS and I'm stuck at
>>> >this now.
>>> >Also tried to build using the raspberry pi with this other tutorial
>>>http://alanstechnotes.blogspot.com/2013/03/compiling-and-installing-rtems-for.html
>>> >and the same happens.
>>> >Any helps is appreciated.
>>> This stuff was added to newlib recently. You need a new toolset.
>>Update the RSB, build tools and you will be OK.
>>> I promise I have built every BSP in the last week.
>>> >Regards, Robert.
>>> --joel
> --joel
> users mailing list
> users at rtems.org
