Resetting Eclipse C compiler choice
    Mr. Andrei Chichak
    groups at chichak.ca
    Wed May 13 20:23:45 UTC 2015
Hi Adit,
RTEMS_MAKEFILE_PATH is set, and in that directory is a file called Makefile.inc that refers to arm-rtems4.11-gcc, as does the content of the make directory files.
Andrei
On 2015-May-13, at 2:11 PM, Adit Sahasrabudhe <asahasra at fb.com> wrote:
> Hi Andrei,
> Have you made sure that your RTEMS_MAKEFILE_PATH is set correctly in eclipse? Unless you set in elsewhere.
> Adit
>> On May 13, 2015, at 12:26 PM, Mr. Andrei Chichak <groups at chichak.ca> wrote:
>> Hi there,
>> I’m using Eclipse on a Mac (hey no snickers, it’s a BSD box) and it was working nicely, using arm-rtems4.11-gcc to do compiles, but it was getting a bit out of date.
>> I grabbed the latest source builder distribution and reinstalled RTEMS tools from scratch.
>> Suddenly Eclipse is using “gcc” to do compiles, which doesn’t exist.
>> I tried munging the make files, but they get rebuilt every time you do a build.
>> I tried munging the .cproject file, but it gets rebuilt every time you do a build.
>> I tried munging the eclipse project preferences C/C++ Build/Settings/Tool Settings/RTEMS C Compiler/Command, but it gets reset on Apply.
>> There are no automake files to deal with.
>> Log off/on reboot doesn’t do it either.
>> Arrg.
>> What is the magic spell that I have to use to reset the compiler name prefix?
>> Thanks a lot,
>> Andrei from the Great White North
>> users mailing list
>> users at rtems.org
