RTEMS ARM build fails, timespec2bintime
Robert Perez
robertperez67 at hotmail.com
Fri May 29 00:19:08 UTC 2015
Thanks Ben.I'm testing RTEMS right now with the virtualbox image but as soon as I can will get a bb and test with it.
Thanks !> Date: Thu, 28 May 2015 14:59:11 +0200
> Subject: Re: RTEMS ARM build fails, timespec2bintime
> From: beng at shrike-systems.com
> To: joel.sherrill at oarcorp.com
> CC: robertperez67 at hotmail.com; users at rtems.org
> All,
> I have rebased and pushed the new branch. I have verified the new
> version builds & the bsp (mainline) works.
> Thanks for your interest in the BSP, I hope it goes well.
> On Tue, May 26, 2015 at 1:20 AM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
> > On May 25, 2015 5:12:09 PM CDT, Robert Perez <robertperez67 at hotmail.com> wrote:
> >>Thanks Joel, I trust you :-)
> >>This could be a simple question but, how to I update the toolset ?
> >>Since I just cloned from Ben Grass git yesterday with:
> > Ahh.. You need his repo to get the qemu that does BB right. But he apparently hasn't rebased against the master at git.rtems.org.
> >>git clone -b beagle https://github.com/bengras/rtems-source-builder.git
> >>I'm looking for it, but a little help is very welcomed.
> >>Thanks !
> >>> From: joel.sherrill at oarcorp.com
> >>> Date: Sun, 24 May 2015 21:51:37 -0500
> >>> To: robertperez67 at hotmail.com; users at rtems.org
> >>> On May 24, 2015 9:13:24 PM CDT, Robert Perez
> >>> >Hi everyone, I'm trying to build RTEMS for the beaglebone using this
> >>> >tutorial
> >>>http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html
> >>> >but when executing the make command some errors are appearing
> >>regarding
> >>> >the timespec2bintime function, seems not to be declared, also some
> >>> >related structs are not recognized (please see the attachment)
> >>> >I've seen in https://sourceware.org/ml/newlib/2015/msg00186.html and
> >>> >https://devel.rtems.org/ticket/2271 changes that could be related to
> >>> >this error as I understand, but I'm new with RTEMS and I'm stuck at
> >>> >this now.
> >>> >Also tried to build using the raspberry pi with this other tutorial
> >>>http://alanstechnotes.blogspot.com/2013/03/compiling-and-installing-rtems-for.html
> >>> >and the same happens.
> >>> >Any helps is appreciated.
> >>> This stuff was added to newlib recently. You need a new toolset.
> >>Update the RSB, build tools and you will be OK.
> >>> I promise I have built every BSP in the last week.
> >>> >Regards, Robert.
> >>> --joel
> > --joel
> > users mailing list
> > users at rtems.org
> > http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20150528/fc5221f7/attachment-0002.html>
