thread allocation blocked by stack size
Wed Nov 4 07:01:03 UTC 2015
On 03/11/15 13:40, Martin Werner wrote:
> On Tue, 2015-11-03 at 09:09 +0100, Sebastian Huber wrote:
>> >Use only:
>> >#define CONFIGURE_UNIFIED_WORK_AREAS
>> >#define CONFIGURE_UNLIMITED_OBJECTS
> I have tried doing this, with no visible change in behaviour.
It may help if you send us the actual source code of your configuration
and a simple test case that reproduces the problem.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
