Compiling with a cpp class
Bruno Oliveira
bruno.manata.oliveira at gmail.com
Wed Nov 11 14:52:39 UTC 2015
Hello, I am compiling a simple test for my SPARC RTEMS. I have an Init task
(declared with extern "C"), and this is how I compile it (Makefile):
# Compiler
CC=sparc-rtems4.11-g++
BSP=-specs bsp_specs -qrtems
LIBS=-B../../leon3/sparc-rtems4.11/leon3/lib
INCLUDES=-I../../leon3/sparc-rtems4.11/leon3/lib/include
FLAGS=-mcpu=cypress -msoft-float -O0 -g -ffunction-sections -fdata-sections
-Wall
CPPFLAGS=-c -Wall -msoft-float
LDFLAGS=-lm
SOURCESCPP=test.cpp image.cpp init.cpp
OBJECTS=$(SOURCESCPP:.cpp=.o)
EXECUTABLE=image_test.exe
all: $(SOURCES) $(EXECUTABLE)
$(EXECUTABLE): $(OBJECTS)
$(CC) $(LIBS) $(BSP) $(FLAGS) $(OBJECTS) $(LDFLAGS) -o $@
.cpp.o:
$(CC) $(INCLUDES) $(FLAGS) $(CPPFLAGS) $< -o $@
clean:
rm -f *.exe *.o *.d
If I compile and link WITH an image.cpp file , which contains a simple c++
class, my code ends and nothing happens. However, If I DO NOT compile with
that image.cpp class, everything works fine. What might be wrong here?
More information: I debugged this with gdb + tsim and found out that it
ends on *threadglobalconstruction.c*
#if defined(EXECUTE_GLOBAL_CONSTRUCTORS)
* _init could be a weak symbol and we SHOULD test it but it isn't
* in any configuration I know of and it generates a warning on every
* RTEMS target configuration. --joel (12 May 2007)
INIT_NAME();
#endif
URL: <http://lists.rtems.org/pipermail/users/attachments/20151111/a1fd8275/attachment.html>
