MinGW Tools locations
Mohammed Saeed Khoory Mohammed.Khoory at mbrsc.ae
Thu Nov 19 04:19:07 UTC 2015
> -----Original Message-----
> From: Chris Johns [mailto:chrisj at rtems.org]
> Sent: Wednesday, November 18, 2015 9:16 AM
> To: Mohammed Saeed Khoory; users at rtems.org
> Subject: Re: MinGW Tools locations
> On 18/11/2015 2:28 PM, Mohammed Saeed Khoory wrote:
> > Looks like I was thrown off by the "rpm" folder name while I was
> searching. I thought it was only RPM-based distro related.
> Those executables were built as rpms.
> > Makes sense. Ood to know. I think the problem with Windows and MinGW
> > though is that it is somewhat difficult to build the tools,
> Have you tried 4.11 and MSYS2 with the RSB?
No. We want to install tools for 4.10.2. The RSB, as far as I know, wasn't made to build for 4.10.2. Is this correct?
> > so we want to keep depending on the same prebuilt packages that we know
> works.
> You can ask the RSB to package the built build set into a tar file so you
> can archive it. If this is important then I encourage you do this.
> Chris
