MinGW Tools locations
Wed Nov 18 05:16:28 UTC 2015
On 18/11/2015 2:28 PM, Mohammed Saeed Khoory wrote:
> Looks like I was thrown off by the "rpm" folder name while I was searching. I thought it was only RPM-based distro related.
Those executables were built as rpms.
> Makes sense. Ood to know. I think the problem with Windows and MinGW though is that it is somewhat difficult to build the tools,
Have you tried 4.11 and MSYS2 with the RSB?
> so we want to keep depending on the same prebuilt packages that we know works.
You can ask the RSB to package the built build set into a tar file so
you can archive it. If this is important then I encourage you do this.
