Beagleboards
Mike Westfall
mike at mesamike.org
Fri Nov 27 15:05:06 UTC 2015
Hi, I am thinking about ordering a Beagleboard xM.
So, I'm trying to get the RTEMS development system for it set up by
following the instructions at
http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html
The building of qemu-linaro failed because of a spurious 'typedef' at line
71 of .../hw/misc/twl4031.c
I fixed this by editing
$HOME/development/rtems/sources/rtems-source-builder/bare/config/devel/qemu-linaro-git-1.cfg
and changed 'qemu_version' to the latest commit (which is
e571600c4a260d3072abbe7ecf2013e48e82bea7).
Next, when configuring the BSPs, I neeeded to add
'--prefix=$HOME/development/rtems/4.11', otherwise when you make it tries
to find things under /opt/rtems/something...
Even after that fix, the build still fails, eventually yielding this:
rtems-syms -e -c "-mcpu=cortex-a8 -O2 -g -Wall -Wmissing-prototypes
-Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs" -o
dl-sym.o dl01.pre
: error trying to exec 'arm-rtems4.12-gcc': execvp: No such file or
directory
What? Why is it looking for arm-rtems4.12-gcc??? So far I've been
unsuccessful in tracking that down.
Anybody have a clue what's going on here?
Mike Westfall
URL: <http://lists.rtems.org/pipermail/users/attachments/20151127/a14e9e77/attachment.html>
