Difficulties building RTEMS
TUAZ TORCHON, Dimitri
dimitri.tuaztorchon at airbus.com
Fri Sep 11 10:04:41 UTC 2015
Hi,
I'm trying to build RTEMS for a Microblaze target, but I have troubles.
Indeed, the compiler tries to seek "creat()" function in libc, but this function is not in libc.
So it generate an error, and I don't know how I can fix it....
Thanks a lot,
Dimtiri Tuaz
Ce courriel (incluant ses eventuelles pieces jointes) peut contenir des informations confidentielles et/ou protegees ou dont la diffusion est restreinte. Si vous avez recu ce courriel par erreur, vous ne devez ni le copier, ni l'utiliser, ni en divulguer le contenu a quiconque. Merci d'en avertir immediatement l'expediteur et d'effacer ce courriel de votre systeme. Airbus Defence and Space et les sociétés Airbus Group declinent toute responsabilite en cas de corruption par virus, d'alteration ou de falsification de ce courriel lors de sa transmission par voie electronique.
This email (including any attachments) may contain confidential and/or privileged information or information otherwise protected from disclosure. If you are not the intended recipient, please notify the sender immediately, do not copy this message or any attachments and do not use it for any purpose or disclose its content to any person, but delete this message and any attachments from your system. Airbus Defence and Space and Airbus Group companies disclaim any and all liability if this email transmission was virus corrupted, altered or falsified.
Airbus Defence and Space SAS (393 341 516 RCS Versailles) - Capital: 16.587.728 EUR - Siege social: 51-61 Route de Verneuil, 78130 Les Mureaux, France
URL: <http://lists.rtems.org/pipermail/users/attachments/20150911/e0684624/attachment.html>
Desc: config.log
URL: <http://lists.rtems.org/pipermail/users/attachments/20150911/e0684624/attachment.obj>
