Difficulties building RTEMS
Fri Sep 11 14:52:38 UTC 2015
On 9/11/2015 9:38 AM, Hesham ALMatary wrote:
> On Fri, Sep 11, 2015 at 2:51 PM, TUAZ TORCHON, Dimitri
> <dimitri.tuaztorchon at airbus.com> wrote:
>> Hi,
>> I’m using your repository, and I get the error I described.
>> So it is not possible to run complex RTEMS applications on a Microblaze ? I have to use a Spartan6 card.
> What configuration options do you use? This is a simple configuration
> line the should work: "--target=rtems-microblaze
> --enable-rtemsbsp=microblaze_fdga  --disable-networking
> --disable-posix"
I suspect that the argument for the target should be:
--target=microblaze-rtems4.11
> I am afraid only hello world sample would work. UART is the only BSP
> driver out there for this BSP currently. I got Hello World running on
> Atlys (Spartan 6) board.
We need to discuss if this is far enough along to merge again now that
we are past a branch. I recall some odd code issues with the vendor HAL
and not running on a simulator at all. But that is a dusty memory.
>> Thanks for your answer,
>> Dimitri
>> From: Hesham ALMatary [mailto:heshamelmatary at gmail.com]
>> Sent: Friday, September 11, 2015 3:41 PM
>> To: TUAZ TORCHON, Dimitri
>> Cc: users at rtems.org
>> Subject: Re: Difficulties building RTEMS
>> Hi,
>> What repos are you using to build RTEMS for microblaze? FYI, there's no microblaze port in RTEMS/upstream. I've worked on an initial port for it, you can find it here [1]. It just runs Hello World sample.
>> [1] https://github.com/heshamelmatary/rtems-microblaze
>> Thanks,
>> Hesham
>> On Fri, Sep 11, 2015 at 11:04 AM, TUAZ TORCHON, Dimitri <dimitri.tuaztorchon at airbus.com> wrote:
>> Hi,
>> I’m trying to build RTEMS for a Microblaze target, but I have troubles.
>> Indeed, the compiler tries to seek “creat()” function in libc, but this function is not in libc.
>> So it generate an error, and I don’t know how I can fix it….
>> Thanks a lot,
>> Dimtiri Tuaz
>> Ce courriel (incluant ses eventuelles pieces jointes) peut contenir des informations confidentielles et/ou protegees ou dont la diffusion est restreinte. Si vous avez recu ce courriel par erreur, vous ne devez ni le copier, ni l'utiliser, ni en divulguer le contenu a quiconque. Merci d'en avertir immediatement l'expediteur et d'effacer ce courriel de votre systeme. Airbus Defence and Space et les sociétés Airbus Group declinent toute responsabilite en cas de corruption par virus, d'alteration ou de falsification de ce courriel lors de sa transmission par voie electronique.
>> This email (including any attachments) may contain confidential and/or privileged information or information otherwise protected from disclosure. If you are not the intended recipient, please notify the sender immediately, do not copy this message or any attachments and do not use it for any purpose or disclose its content to any person, but delete this message and any attachments from your system. Airbus Defence and Space and Airbus Group companies disclaim any and all liability if this email transmission was virus corrupted, altered or falsified.
>> Airbus Defence and Space SAS (393 341 516 RCS Versailles) - Capital: 16.587.728 EUR - Siege social: 51-61 Route de Verneuil, 78130 Les Mureaux, France
>> users mailing list
>> users at rtems.org
>> Hesham
