Difficulties building RTEMS
Hesham ALMatary heshamelmatary at gmail.com
Fri Sep 11 15:00:45 UTC 2015
On Fri, Sep 11, 2015 at 3:52 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On 9/11/2015 9:38 AM, Hesham ALMatary wrote:
>> On Fri, Sep 11, 2015 at 2:51 PM, TUAZ TORCHON, Dimitri
>> <dimitri.tuaztorchon at airbus.com> wrote:
>>> Hi,
>>> I’m using your repository, and I get the error I described.
>>> So it is not possible to run complex RTEMS applications on a Microblaze ?
>>> I have to use a Spartan6 card.
>> What configuration options do you use? This is a simple configuration
>> line the should work: "--target=rtems-microblaze
>> --enable-rtemsbsp=microblaze_fdga  --disable-networking
>> --disable-posix"
> I suspect that the argument for the target should be:
Yeah sorry my bad.
> --target=microblaze-rtems4.11
>> I am afraid only hello world sample would work. UART is the only BSP
>> driver out there for this BSP currently. I got Hello World running on
>> Atlys (Spartan 6) board.
> We need to discuss if this is far enough along to merge again now that
> we are past a branch. I recall some odd code issues with the vendor HAL
> and not running on a simulator at all. But that is a dusty memory.
I didn't run it on the simulator at all, instead I worked directory
with the FPGA. I can see that there's some interest on this port,
which is a good motivation to work on upstreaming it. I'll try to
clean-up the code and send initial patches, but there're no timing
guarantees since I'm pretty busy with school and moving out stuff.
>>> Thanks for your answer,
>>> Dimitri
>>> From: Hesham ALMatary [mailto:heshamelmatary at gmail.com]
>>> Sent: Friday, September 11, 2015 3:41 PM
>>> To: TUAZ TORCHON, Dimitri
>>> Cc: users at rtems.org
>>> Subject: Re: Difficulties building RTEMS
>>> Hi,
>>> What repos are you using to build RTEMS for microblaze? FYI, there's no
>>> microblaze port in RTEMS/upstream. I've worked on an initial port for it,
>>> you can find it here [1]. It just runs Hello World sample.
>>> [1] https://github.com/heshamelmatary/rtems-microblaze
>>> Thanks,
>>> Hesham
>>> On Fri, Sep 11, 2015 at 11:04 AM, TUAZ TORCHON, Dimitri
>>> Hi,
>>> I’m trying to build RTEMS for a Microblaze target, but I have troubles.
>>> Indeed, the compiler tries to seek “creat()” function in libc, but this
>>> function is not in libc.
>>> So it generate an error, and I don’t know how I can fix it….
>>> Thanks a lot,
>>> Dimtiri Tuaz
>>> Ce courriel (incluant ses eventuelles pieces jointes) peut contenir des
>>> informations confidentielles et/ou protegees ou dont la diffusion est
>>> restreinte. Si vous avez recu ce courriel par erreur, vous ne devez ni le
>>> copier, ni l'utiliser, ni en divulguer le contenu a quiconque. Merci d'en
>>> avertir immediatement l'expediteur et d'effacer ce courriel de votre
>>> systeme. Airbus Defence and Space et les sociétés Airbus Group declinent
>>> toute responsabilite en cas de corruption par virus, d'alteration ou de
>>> falsification de ce courriel lors de sa transmission par voie electronique.
>>> This email (including any attachments) may contain confidential and/or
>>> privileged information or information otherwise protected from disclosure.
>>> If you are not the intended recipient, please notify the sender immediately,
>>> do not copy this message or any attachments and do not use it for any
>>> purpose or disclose its content to any person, but delete this message and
>>> any attachments from your system. Airbus Defence and Space and Airbus Group
>>> companies disclaim any and all liability if this email transmission was
>>> virus corrupted, altered or falsified.
>>> Airbus Defence and Space SAS (393 341 516 RCS Versailles) - Capital:
>>> 16.587.728 EUR - Siege social: 51-61 Route de Verneuil, 78130 Les Mureaux,
>>> France
>>> users mailing list
>>> users at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/users
>>> Hesham
>>> France
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
Hesham
