Difficulties building RTEMS
Fri Sep 18 14:29:00 UTC 2015
I think this is code added after you did the port was done. Hesham.. Look at the generic cache code and see what other ports have done.
On September 18, 2015 8:40:38 AM CDT, "TUAZ TORCHON, Dimitri" <dimitri.tuaztorchon at airbus.com> wrote:
>Yes, I re-downloaded your repo a few hours ago, and run bootstrap –p
>and bootstrap, but I’m having the same error again and again…
>From: Hesham ALMatary [mailto:heshamelmatary at gmail.com]
>Sent: Friday, September 18, 2015 2:34 PM
>To: TUAZ TORCHON, Dimitri
>Cc: users at rtems.org
>Subject: RE: Difficulties building RTEMS
>Hi,
>I don't know why you are getting this error. Are you sure you're using
>my repo? And have you run bootstrap -p and bootstrap?
>On Sep 18, 2015 10:34 AM, "TUAZ TORCHON, Dimitri"
>Hi,
>Indeed, using RSB is more simple ! I configured it with option
>"--without-rtems" because I want to compile the version with the
>microblaze bsp.
>But when compiling rtems-microblaze (with configuration line
>--target=microblaze-rtems4.11  --disable-networking --disable-posix
>--disable-cxx --enable-rtemsbsp=microblaze_fpga --prefix=$HOME/rtems),
>I got an error :
>../../../../../microblaze_fpga/lib/librtemscpu.a(libcsupport_a-cachealignedalloc.o):
>In function `rtems_cache_aligned_malloc':
>/projets/1007/stage/rtos/b-rtems/microblaze-rtems4.11/c/microblaze_fpga/cpukit/libcsupport/../../../../../../rtems-microblaze/c/src/../../cpukit/libcsupport/src/cachealignedalloc.c:18:
>undefined reference to `rtems_cache_get_data_line_size'
>collect2: error: ld returned 1 exit status
>I checked cachealignedalloc.c, and this .c file include <rtems.h>,
>which include <rtems.h/cache.h> in which there is a declaration of
>rtems_cache_get_data_line_size. So I think the error occurs during the
>linking (and one line above, we see that ld returned exit status.)
>In order to see if the linker works, I tried  to create an executable
>with a simple .c file, and I got this warning :
>"$HOME/development/rtems/4.11/lib/gcc/microblaze-rtems4.11/4.9.3/../../../../microblaze-rtems4.11/bin/ld:
>warning: cannot find entry symbol _start; defaulting to
>0000000000000050"
>Does this mean that the linker can't find the linker script ? Yet, the
>source builder did not pick up any error...
>Thanks for your help
>-----Original Message-----
>Sent: Wednesday, September 16, 2015 11:03 AM
>Subject: Re: Difficulties building RTEMS
>On Wed, Sep 16, 2015 at 9:54 AM, TUAZ TORCHON, Dimitri
>> I followed the guide "Getting started with RTEMS". But I've found a
>solution : I introduced the "creat()" in libgloss. And then I figured
>out than other functions were missing to (opendir, closed, readdir,...)
>You should use RTEMS Source Builder (RSB) [1] to install the
>MicroBlaze toolchain for RTEMS (if you haven't already). RTEMS is not
>using any libgloss stuff.
>[1] https://docs.rtems.org/rsb/
>> Sent: Wednesday, September 16, 2015 10:43 AM
>> On Tue, Sep 15, 2015 at 9:09 AM, TUAZ TORCHON, Dimitri
>>> Hi,
>>> It's the configuration options I use, but when I make "make all", I
>still have the error :
>>> "checking for creat... no
>>> configure: error: Missing function creat in libc
>>> configure: error: /bin/sh
>'../../../../../rtems-microblaze/c/src/../../cpukit/configure' failed
>for ../../cpukit
>>> gmake[2]: *** [microblaze_fpga] Error 1"
>> How did you install the toolchain?
>>> And indeed, when I check into libc, there is no function creat. I
>figured out that it is an obsolete function now.
>>> Sent: Friday, September 11, 2015 5:01 PM
>>> To: Joel Sherrill
>>> Cc: TUAZ TORCHON, Dimitri; users at rtems.org
>>> On Fri, Sep 11, 2015 at 3:52 PM, Joel Sherrill
>>> <joel.sherrill at oarcorp.com> wrote:
>>>> On 9/11/2015 9:38 AM, Hesham ALMatary wrote:
>>>>> On Fri, Sep 11, 2015 at 2:51 PM, TUAZ TORCHON, Dimitri
>>>>>> Hi,
>>>>>> I’m using your repository, and I get the error I described.
>>>>>> So it is not possible to run complex RTEMS applications on a
>Microblaze ?
>>>>>> I have to use a Spartan6 card.
>>>>> What configuration options do you use? This is a simple
>configuration
>>>>> line the should work: "--target=rtems-microblaze
>>>>> --enable-rtemsbsp=microblaze_fdga  --disable-networking
>>>>> --disable-posix"
>>>> I suspect that the argument for the target should be:
>>> Yeah sorry my bad.
>>>>> I am afraid only hello world sample would work. UART is the only
>BSP
>>>>> driver out there for this BSP currently. I got Hello World running
>on
>>>>> Atlys (Spartan 6) board.
>>>> We need to discuss if this is far enough along to merge again now
>that
>>>> we are past a branch. I recall some odd code issues with the vendor
>HAL
>>>> and not running on a simulator at all. But that is a dusty memory.
>>> I didn't run it on the simulator at all, instead I worked directory
>>> with the FPGA. I can see that there's some interest on this port,
>>> which is a good motivation to work on upstreaming it. I'll try to
>>> clean-up the code and send initial patches, but there're no timing
>>> guarantees since I'm pretty busy with school and moving out stuff.
>>>>>> Thanks for your answer,
>>>>>> Dimitri
>>>>>> Sent: Friday, September 11, 2015 3:41 PM
>>>>>> Hi,
>>>>>> What repos are you using to build RTEMS for microblaze? FYI,
>there's no
>>>>>> microblaze port in RTEMS/upstream. I've worked on an initial port
>for it,
>>>>>> you can find it here [1]. It just runs Hello World sample.
>>>>>> [1] https://github.com/heshamelmatary/rtems-microblaze
>>>>>> Thanks,
>>>>>> Hesham
>>>>>> On Fri, Sep 11, 2015 at 11:04 AM, TUAZ TORCHON, Dimitri
>>>>>> Hi,
>>>>>> I’m trying to build RTEMS for a Microblaze target, but I have
>troubles.
>>>>>> Indeed, the compiler tries to seek “creat()” function in libc,
>but this
>>>>>> function is not in libc.
>>>>>> So it generate an error, and I don’t know how I can fix it….
>>>>>> Thanks a lot,
>>>>>> Dimtiri Tuaz
>>>>>> Ce courriel (incluant ses eventuelles pieces jointes) peut
>contenir des
>>>>>> informations confidentielles et/ou protegees ou dont la diffusion
>est
>>>>>> restreinte. Si vous avez recu ce courriel par erreur, vous ne
>devez ni le
>>>>>> copier, ni l'utiliser, ni en divulguer le contenu a quiconque.
>Merci d'en
>>>>>> avertir immediatement l'expediteur et d'effacer ce courriel de
>votre
>>>>>> systeme. Airbus Defence and Space et les sociétés Airbus Group
>declinent
>>>>>> toute responsabilite en cas de corruption par virus, d'alteration
>ou de
>>>>>> falsification de ce courriel lors de sa transmission par voie
>electronique.
>>>>>> This email (including any attachments) may contain confidential
>and/or
>>>>>> privileged information or information otherwise protected from
>disclosure.
>>>>>> If you are not the intended recipient, please notify the sender
>immediately,
>>>>>> do not copy this message or any attachments and do not use it for
>any
>>>>>> purpose or disclose its content to any person, but delete this
>message and
>>>>>> any attachments from your system. Airbus Defence and Space and
>Airbus Group
>>>>>> companies disclaim any and all liability if this email
>transmission was
>>>>>> virus corrupted, altered or falsified.
>>>>>> Airbus Defence and Space SAS (393 341 516 RCS Versailles) -
>Capital:
>>>>>> 16.587.728 EUR - Siege social: 51-61 Route de Verneuil, 78130 Les
>Mureaux,
>>>>>> France
>>>>>> _______________________________________________
>>>>>> users mailing list
>>>>>> users at rtems.org
>>>>>> http://lists.rtems.org/mailman/listinfo/users
>>>>>> Hesham
>contenir des
>est
>devez ni le
>Merci d'en
>votre
>declinent
>ou de
>electronique.
>and/or
>disclosure.
>immediately,
>any
>message and
>Airbus Group
>transmission was
>Capital:
>Mureaux,
>>>>>> France
>>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>> Support Available                (256) 722-9985
>>> Hesham
>>> This mail has originated outside your organization, either from an
>external partner or the Global Internet.
>>> Keep this in mind if you answer this message.
>>> Ce courriel (incluant ses eventuelles pieces jointes) peut contenir
>des informations confidentielles et/ou protegees ou dont la diffusion
>est restreinte. Si vous avez recu ce courriel par erreur, vous ne devez
>ni le copier, ni l'utiliser, ni en divulguer le contenu a quiconque.
>Merci d'en avertir immediatement l'expediteur et d'effacer ce courriel
>de votre systeme. Airbus Defence and Space et les sociétés Airbus Group
>declinent toute responsabilite en cas de corruption par virus,
>d'alteration ou de falsification de ce courriel lors de sa transmission
>par voie electronique.
>and/or privileged information or information otherwise protected from
>disclosure. If you are not the intended recipient, please notify the
>sender immediately, do not copy this message or any attachments and do
>not use it for any purpose or disclose its content to any person, but
>delete this message and any attachments from your system. Airbus
>Defence and Space and Airbus Group companies disclaim any and all
>liability if this email transmission was virus corrupted, altered or
>falsified.
>>> Airbus Defence and Space SAS (393 341 516 RCS Versailles) - Capital:
>Mureaux, France
>> Hesham
>falsified.
>Mureaux, France
>Hesham
>Ce courriel (incluant ses eventuelles pieces jointes) peut contenir des
>informations confidentielles et/ou protegees ou dont la diffusion est
>restreinte. Si vous avez recu ce courriel par erreur, vous ne devez ni
>le copier, ni l'utiliser, ni en divulguer le contenu a quiconque. Merci
>d'en avertir immediatement l'expediteur et d'effacer ce courriel de
>This email (including any attachments) may contain confidential and/or
>falsified.
>Mureaux, France
>*************************************************************** Ce
>par voie electronique. This email (including any attachments) may
>contain confidential and/or privileged information or information
>otherwise protected from disclosure. If you are not the intended
>recipient, please notify the sender immediately, do not copy this
>message or any attachments and do not use it for any purpose or
>disclose its content to any person, but delete this message and any
>attachments from your system. Airbus Defence and Space and Airbus Group
>companies disclaim any and all liability if this email transmission was
>Mureaux, France
--joel
