Difficulties building RTEMS
Hesham ALMatary heshamelmatary at gmail.com
Fri Sep 18 14:45:05 UTC 2015
On Fri, Sep 18, 2015 at 3:29 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> I think this is code added after you did the port was done. Hesham.. Look at the generic cache code and see what other ports have done.
It won't matter, I am using my own repo [1] and didn't update/rebase
against master since it was working. I've just cloned and rebuilt it
again now, and I got no such error. I suspect Tuaz is missing
something. Tuaz, It maybe helpful if you provided full details how you
set up the toolchain and RTEMS with configuration options, and full
error log.
[1] https://github.com/heshamelmatary/rtems-microblaze
> On September 18, 2015 8:40:38 AM CDT, "TUAZ TORCHON, Dimitri" <dimitri.tuaztorchon at airbus.com> wrote:
>>Yes, I re-downloaded your repo a few hours ago, and run bootstrap –p
>>and bootstrap, but I’m having the same error again and again…
>>From: Hesham ALMatary [mailto:heshamelmatary at gmail.com]
>>Sent: Friday, September 18, 2015 2:34 PM
>>To: TUAZ TORCHON, Dimitri
>>Cc: users at rtems.org
>>Subject: RE: Difficulties building RTEMS
>>Hi,
>>I don't know why you are getting this error. Are you sure you're using
>>my repo? And have you run bootstrap -p and bootstrap?
>>On Sep 18, 2015 10:34 AM, "TUAZ TORCHON, Dimitri"
>>Hi,
>>Indeed, using RSB is more simple ! I configured it with option
>>"--without-rtems" because I want to compile the version with the
>>microblaze bsp.
>>But when compiling rtems-microblaze (with configuration line
>>--target=microblaze-rtems4.11  --disable-networking --disable-posix
>>--disable-cxx --enable-rtemsbsp=microblaze_fpga --prefix=$HOME/rtems),
>>I got an error :
>>../../../../../microblaze_fpga/lib/librtemscpu.a(libcsupport_a-cachealignedalloc.o):
>>In function `rtems_cache_aligned_malloc':
>>/projets/1007/stage/rtos/b-rtems/microblaze-rtems4.11/c/microblaze_fpga/cpukit/libcsupport/../../../../../../rtems-microblaze/c/src/../../cpukit/libcsupport/src/cachealignedalloc.c:18:
>>undefined reference to `rtems_cache_get_data_line_size'
>>collect2: error: ld returned 1 exit status
>>I checked cachealignedalloc.c, and this .c file include <rtems.h>,
>>which include <rtems.h/cache.h> in which there is a declaration of
>>rtems_cache_get_data_line_size. So I think the error occurs during the
>>linking (and one line above, we see that ld returned exit status.)
>>In order to see if the linker works, I tried  to create an executable
>>with a simple .c file, and I got this warning :
>>"$HOME/development/rtems/4.11/lib/gcc/microblaze-rtems4.11/4.9.3/../../../../microblaze-rtems4.11/bin/ld:
>>warning: cannot find entry symbol _start; defaulting to
>>0000000000000050"
>>Does this mean that the linker can't find the linker script ? Yet, the
>>source builder did not pick up any error...
>>Thanks for your help
>>-----Original Message-----
>>Sent: Wednesday, September 16, 2015 11:03 AM
>>Subject: Re: Difficulties building RTEMS
>>On Wed, Sep 16, 2015 at 9:54 AM, TUAZ TORCHON, Dimitri
>>> I followed the guide "Getting started with RTEMS". But I've found a
>>solution : I introduced the "creat()" in libgloss. And then I figured
>>out than other functions were missing to (opendir, closed, readdir,...)
>>You should use RTEMS Source Builder (RSB) [1] to install the
>>MicroBlaze toolchain for RTEMS (if you haven't already). RTEMS is not
>>using any libgloss stuff.
>>[1] https://docs.rtems.org/rsb/
>>> Sent: Wednesday, September 16, 2015 10:43 AM
>>> On Tue, Sep 15, 2015 at 9:09 AM, TUAZ TORCHON, Dimitri
>>>> Hi,
>>>> It's the configuration options I use, but when I make "make all", I
>>still have the error :
>>>> "checking for creat... no
>>>> configure: error: Missing function creat in libc
>>>> configure: error: /bin/sh
>>'../../../../../rtems-microblaze/c/src/../../cpukit/configure' failed
>>for ../../cpukit
>>>> gmake[2]: *** [microblaze_fpga] Error 1"
>>> How did you install the toolchain?
>>>> And indeed, when I check into libc, there is no function creat. I
>>figured out that it is an obsolete function now.
>>>> Sent: Friday, September 11, 2015 5:01 PM
>>>> To: Joel Sherrill
>>>> Cc: TUAZ TORCHON, Dimitri; users at rtems.org
>>>> On Fri, Sep 11, 2015 at 3:52 PM, Joel Sherrill
>>>>> On 9/11/2015 9:38 AM, Hesham ALMatary wrote:
>>>>>> On Fri, Sep 11, 2015 at 2:51 PM, TUAZ TORCHON, Dimitri
>>>>>>> Hi,
>>>>>>> I’m using your repository, and I get the error I described.
>>>>>>> So it is not possible to run complex RTEMS applications on a
>>Microblaze ?
>>>>>>> I have to use a Spartan6 card.
>>>>>> What configuration options do you use? This is a simple
>>configuration
>>>>>> line the should work: "--target=rtems-microblaze
>>>>>> --enable-rtemsbsp=microblaze_fdga  --disable-networking
>>>>>> --disable-posix"
>>>>> I suspect that the argument for the target should be:
>>>> Yeah sorry my bad.
>>>>>> I am afraid only hello world sample would work. UART is the only
>>BSP
>>>>>> driver out there for this BSP currently. I got Hello World running
>>on
>>>>>> Atlys (Spartan 6) board.
>>>>> We need to discuss if this is far enough along to merge again now
>>that
>>>>> we are past a branch. I recall some odd code issues with the vendor
>>HAL
>>>>> and not running on a simulator at all. But that is a dusty memory.
>>>> I didn't run it on the simulator at all, instead I worked directory
>>>> with the FPGA. I can see that there's some interest on this port,
>>>> which is a good motivation to work on upstreaming it. I'll try to
>>>> clean-up the code and send initial patches, but there're no timing
>>>> guarantees since I'm pretty busy with school and moving out stuff.
>>>>>>> Thanks for your answer,
>>>>>>> Dimitri
>>>>>>> Sent: Friday, September 11, 2015 3:41 PM
>>>>>>> Hi,
>>>>>>> What repos are you using to build RTEMS for microblaze? FYI,
>>there's no
>>>>>>> microblaze port in RTEMS/upstream. I've worked on an initial port
>>for it,
>>>>>>> you can find it here [1]. It just runs Hello World sample.
>>>>>>> Thanks,
>>>>>>> Hesham
>>>>>>> On Fri, Sep 11, 2015 at 11:04 AM, TUAZ TORCHON, Dimitri
>>>>>>> Hi,
>>>>>>> I’m trying to build RTEMS for a Microblaze target, but I have
>>troubles.
>>>>>>> Indeed, the compiler tries to seek “creat()” function in libc,
>>but this
>>>>>>> function is not in libc.
>>>>>>> So it generate an error, and I don’t know how I can fix it….
>>>>>>> Thanks a lot,
>>>>>>> Dimtiri Tuaz
>>>>>>> Ce courriel (incluant ses eventuelles pieces jointes) peut
>>contenir des
>>>>>>> informations confidentielles et/ou protegees ou dont la diffusion
>>est
>>>>>>> restreinte. Si vous avez recu ce courriel par erreur, vous ne
>>devez ni le
>>>>>>> copier, ni l'utiliser, ni en divulguer le contenu a quiconque.
>>Merci d'en
>>>>>>> avertir immediatement l'expediteur et d'effacer ce courriel de
>>votre
>>>>>>> systeme. Airbus Defence and Space et les sociétés Airbus Group
>>declinent
>>>>>>> toute responsabilite en cas de corruption par virus, d'alteration
>>ou de
>>>>>>> falsification de ce courriel lors de sa transmission par voie
>>electronique.
>>>>>>> This email (including any attachments) may contain confidential
>>and/or
>>>>>>> privileged information or information otherwise protected from
>>disclosure.
>>>>>>> If you are not the intended recipient, please notify the sender
>>immediately,
>>>>>>> do not copy this message or any attachments and do not use it for
>>any
>>>>>>> purpose or disclose its content to any person, but delete this
>>message and
>>>>>>> any attachments from your system. Airbus Defence and Space and
>>Airbus Group
>>>>>>> companies disclaim any and all liability if this email
>>transmission was
>>>>>>> virus corrupted, altered or falsified.
>>>>>>> Airbus Defence and Space SAS (393 341 516 RCS Versailles) -
>>Capital:
>>>>>>> 16.587.728 EUR - Siege social: 51-61 Route de Verneuil, 78130 Les
>>Mureaux,
>>>>>>> France
>>>>>>> _______________________________________________
>>>>>>> users mailing list
>>>>>>> users at rtems.org
>>>>>>> http://lists.rtems.org/mailman/listinfo/users
>>>>>>> Hesham
>>contenir des
>>est
>>devez ni le
>>Merci d'en
>>votre
>>declinent
>>ou de
>>electronique.
>>and/or
>>disclosure.
>>immediately,
>>any
>>message and
>>Airbus Group
>>transmission was
>>Capital:
>>Mureaux,
>>>>>>> France
>>>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>>> Support Available                (256) 722-9985
>>>> Hesham
>>>> This mail has originated outside your organization, either from an
>>external partner or the Global Internet.
>>>> Keep this in mind if you answer this message.
>>>> Ce courriel (incluant ses eventuelles pieces jointes) peut contenir
>>des informations confidentielles et/ou protegees ou dont la diffusion
>>est restreinte. Si vous avez recu ce courriel par erreur, vous ne devez
>>ni le copier, ni l'utiliser, ni en divulguer le contenu a quiconque.
>>Merci d'en avertir immediatement l'expediteur et d'effacer ce courriel
>>de votre systeme. Airbus Defence and Space et les sociétés Airbus Group
>>declinent toute responsabilite en cas de corruption par virus,
>>d'alteration ou de falsification de ce courriel lors de sa transmission
>>par voie electronique.
>>and/or privileged information or information otherwise protected from
>>disclosure. If you are not the intended recipient, please notify the
>>sender immediately, do not copy this message or any attachments and do
>>not use it for any purpose or disclose its content to any person, but
>>delete this message and any attachments from your system. Airbus
>>Defence and Space and Airbus Group companies disclaim any and all
>>liability if this email transmission was virus corrupted, altered or
>>falsified.
>>>> Airbus Defence and Space SAS (393 341 516 RCS Versailles) - Capital:
>>Mureaux, France
>>> Hesham
>>falsified.
>>Mureaux, France
>>Hesham
>>Ce courriel (incluant ses eventuelles pieces jointes) peut contenir des
>>informations confidentielles et/ou protegees ou dont la diffusion est
>>restreinte. Si vous avez recu ce courriel par erreur, vous ne devez ni
>>le copier, ni l'utiliser, ni en divulguer le contenu a quiconque. Merci
>>d'en avertir immediatement l'expediteur et d'effacer ce courriel de
>>This email (including any attachments) may contain confidential and/or
>>falsified.
>>Mureaux, France
>>*************************************************************** Ce
>>par voie electronique. This email (including any attachments) may
>>contain confidential and/or privileged information or information
>>otherwise protected from disclosure. If you are not the intended
>>recipient, please notify the sender immediately, do not copy this
>>message or any attachments and do not use it for any purpose or
>>disclose its content to any person, but delete this message and any
>>attachments from your system. Airbus Defence and Space and Airbus Group
>>companies disclaim any and all liability if this email transmission was
>>Mureaux, France
> --joel
Hesham
