large bss size for sample applications
Jeff Webb jeff.webb at nta-inc.net
Fri Sep 25 13:04:58 UTC 2015
On 09/25/2015 07:59 AM, Gedare Bloom wrote:
>> The next task for me will be to set up a simple out-of tree C or C++ POSIX
>> application.
>> Thanks again for all the help!
>> -Jeff
> Simple examples for out-of-tree builds exist in the examples-v2.git
> repository with the "RTEMS Application Makefile" approach using custom
> Makefiles, and with the "RTEMS Application Waf" approach using
> wscripts and a git-submodule for waf support. The former is an older,
> established way to build applications linking to an 'installed' RTEMS,
> and the latter is a newer way to do it.
Perfect!  This is just what I need.  Thanks for the pointer.
-Jeff
