large bss size for sample applications
Sat Sep 26 06:36:27 UTC 2015
On 25/09/2015 11:04 pm, Jeff Webb wrote:
> On 09/25/2015 07:59 AM, Gedare Bloom wrote:
>>> The next task for me will be to set up a simple out-of tree C or C++
>>> POSIX
>>> application.
>>> Thanks again for all the help!
>>> -Jeff
>> Simple examples for out-of-tree builds exist in the examples-v2.git
>> repository with the "RTEMS Application Makefile" approach using custom
>> Makefiles, and with the "RTEMS Application Waf" approach using
>> wscripts and a git-submodule for waf support. The former is an older,
>> established way to build applications linking to an 'installed' RTEMS,
>> and the latter is a newer way to do it.
> Perfect!  This is just what I need.  Thanks for the pointer.
The Makefile approach will not be supported with the waf build of RTEMS
when it lands.
