how to use mutex
Chan Kim
ckim at etri.re.kr
Wed Sep 2 13:39:29 UTC 2015
Hi, Gedare,
> Note also that you must account for how many resources (including
> semaphores) your program requires via the CONFIGURE_ macros. Check that
> you have enough semaphores configured there. For simplicity there is an
> option to enable unlimited objects that can ease this issue for
> development/porting efforts.
I'm debugging other scenario now, but I'll add
#define CONFIGURE_MAXIMUM_SEMAPHORES 20
in my app and try later.
Thanks!
Chan Kim
보낸 사람 : "Gedare Bloom" <gedare at rtems.org>
보낸 날짜 : 2015-09-02 22:26:23 ( +09:00 )
받는 사람 : 김찬 <ckim at etri.re.kr>
참조 : users at rtems.org <users at rtems.org>
제목 : Re: how to use mutex
that you have enough semaphores configured there. For simplicity there
is an option to enable unlimited objects that can ease this issue for
On Tue, Sep 1, 2015 at 10:50 PM, Paul Whitfield
wrote:
> Hi Chan Kim,
> The result code you are displaying in your debug output is 4, This is not 0, RTEMS_SUCCESSFUL.
> So the call to obtain the semaphore has failed.
> That result code can be found in rtems/status.h
> The result code is RTEMS_INVALID_ID, so you have a programming error, you are not accessing the semaphore with a valid ID.
> Regards
> Paul Whitfield.
> -----Original Message-----
> From: users [mailto:users-bounces at rtems.org] On Behalf Of Chan Kim
> Sent: Wednesday, 2 September 2015 10:28 AM
> To: users at rtems.org
> Subject: RE: how to use mutex
> I tried it with semaphore
> for init,
> rtems_attribute sem_attr;
> rtems_status_code status;
> sem_attr = RTEMS_INHERIT_PRIORITY | RTEMS_BINARY_SEMAPHORE | RTEMS_PRIORITY;
> sem_name = rtems_build_name( 'S','0',' ',' ');
> status = rtems_semaphore_create( sem_name, 1, sem_attr, 0, &sem_id);
> printk("semaphore created status = %d\n", status);
> to obtain, (read case, write thread the same)
> status = rtems_semaphore_obtain( sem_id, RTEMS_WAIT, 0);
> printk("locked from read..status = %d\n", status);
> to release (read case, write thread the same)
> printk("unlocking from read..\n");
> rtems_semaphore_release( sem_id);
> I get result
> locked from read..status = 0
> locked from read..status = 4
> locked from write.. status = 4
> unlocking from write..
> locked from write.. status = 4 <===== read locked it, but write entered it.
> status code 4 is RTEMS_INVALID_ID meaning object ID is invalid. I don't know what's wrong.
> can anyone tell me what's wrong?
> Chan
> 보낸 사람 : "Chan Kim"
> 보낸 날짜 : 2015-09-02 10:26:24 ( +09:00 )
> 받는 사람 : users at rtems.org 참조 :
> 제목 : how to use mutex
> Hello, rtems users,
> Please somebody help with with using mutex.
> To avoid sync problem by simpling serializing read and write processing, I tried using mutex and found it's not working properly.
> ------------ the way I did it
> pthread_mutexattr_t mutex_attr;
> pthread_mutex_t rd_wr_mutex;
> to initialize,
> statusi = pthread_mutexattr_init( &mutex_attr ); printk("mutext attri init result = %x\n", statusi); pthread_mutex_init(&rd_wr_mutex, &mutex_attr); printk("mutext init result = %x\n", statusi);
> to lock,
> pthread_mutex_lock(&rd_wr_mutex); // rtems_mutex_t printk("locked from read..\n");
> to unlock,
> pthread_mutex_unlock(&rd_wr_mutex);
> I see results (only mutex lock, unlock prints)
> mutext attr init result = 0
> mutext init result = 0
> locked from read..
> locked from write..
> locked from write..
> locked from write..
> locked from read..
> locked from write.. <===== ???
> Print result shows teh write thread enters it when read thread has locked it. What's wrong with the way of my using mutex?
> Hope someone clears it with some explanation.
> Thanks,
> regards,
> Chan Kim
> users mailing list
> users at rtems.org
> users mailing list
> users at rtems.org
> users mailing list
> users at rtems.org
