Difficulties building RTEMS
TUAZ TORCHON, Dimitri
dimitri.tuaztorchon at airbus.com
Mon Sep 21 15:02:13 UTC 2015
I cloned git://git.rtems.org/rtems-crossrpms.git, and found these infos in rtems-crossrpsm/rtems4.11/microblaze/Makefile.am (as described in the guide)
-----Original Message-----
From: gedare at gwmail.gwu.edu [mailto:gedare at gwmail.gwu.edu] On Behalf Of Gedare Bloom
Sent: Monday, September 21, 2015 3:24 PM
To: TUAZ TORCHON, Dimitri
Cc: Joel Sherrill; Hesham ALMatary; users at rtems.org
Subject: Re: Difficulties building RTEMS
On Mon, Sep 21, 2015 at 5:20 AM, TUAZ TORCHON, Dimitri
<dimitri.tuaztorchon at airbus.com> wrote:
> - I notice that, because I first tried to install by hand the toolchain (following the "Getting Started with RTEMS" guide). Following this guide, I have to install :
> Autoconf 2.69
> Automake 1.13.4
> Binutils 2.24
> GCC 4.8.2
> Newlib 1.20.0
> GDB 7.7.1
Where did you find this doc linked from? The tools it says to build
are out-dated. I think we removed this guide from the official
rtems.git already, or at least re-wrote it.
This mail has originated outside your organization, either from an external partner or the Global Internet.
Keep this in mind if you answer this message.
Ce courriel (incluant ses eventuelles pieces jointes) peut contenir des informations confidentielles et/ou protegees ou dont la diffusion est restreinte. Si vous avez recu ce courriel par erreur, vous ne devez ni le copier, ni l'utiliser, ni en divulguer le contenu a quiconque. Merci d'en avertir immediatement l'expediteur et d'effacer ce courriel de votre systeme. Airbus Defence and Space et les sociétés Airbus Group declinent toute responsabilite en cas de corruption par virus, d'alteration ou de falsification de ce courriel lors de sa transmission par voie electronique.
This email (including any attachments) may contain confidential and/or privileged information or information otherwise protected from disclosure. If you are not the intended recipient, please notify the sender immediately, do not copy this message or any attachments and do not use it for any purpose or disclose its content to any person, but delete this message and any attachments from your system. Airbus Defence and Space and Airbus Group companies disclaim any and all liability if this email transmission was virus corrupted, altered or falsified.
Airbus Defence and Space SAS (393 341 516 RCS Versailles) - Capital: 16.587.728 EUR - Siege social: 51-61 Route de Verneuil, 78130 Les Mureaux, France
