Difficulties building RTEMS
TUAZ TORCHON, Dimitri
dimitri.tuaztorchon at airbus.com
Mon Sep 21 15:12:13 UTC 2015
Indeed, configured with --without-tests, it compiled ! Thanks a lot for your help :)
However, I can't compile the hello world example (I've got this message
"make -f MAKEFILE= VARIANT=DEBUG
make[1]: Entering directory `/projets/1007/stage/rtos/examples-v2/hello/hello_world_c'
make[1]: MAKEFILE=: No such file or directory
make[1]: *** No rule to make target `MAKEFILE='. Stop.
make[1]: Leaving directory `/projets/1007/stage/rtos/examples-v2/hello/hello_world_c'
make: *** [debug] Error 2"
When executing "make").
I think there is a problem with some "include" directive, because variable MAKEFILE seems empty, but is well defined in make/main.cfg
I noticed there were some warning during RTEMS compiling, I hope these issues are not related...
Again, thanks a lot for your help !
-----Original Message-----
From: Hesham ALMatary [mailto:heshamelmatary at gmail.com]
Sent: Monday, September 21, 2015 1:37 PM
To: Joel Sherrill
Cc: TUAZ TORCHON, Dimitri; users at rtems.org
Subject: Re: Difficulties building RTEMS
OK after checking your log file, you already have got hello world exe
built/compiled and some other samples. For example the following
snippet |(from your log) gives you details about the hello world exe:
"microblaze-rtems4.11-gcc -B../../../../../microblaze_fpga/lib/ -specs
bsp_specs -qrtems -O0 -g -Wall -Wmissing-prototypes
-Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs
-o hello.exe init.o
microblaze-rtems4.11-nm -g -n hello.exe > hello.num
microblaze-rtems4.11-size hello.exe
text data bss dec hex filename
250304 772 16526172 16777248 1000020 hello.exe"
So there's nothing wrong, and everything is working as expected. The
error you're getting is due to missing features/drivers (like Cache,
Timer, etc) that the later corresponding samples rely on.
On Mon, Sep 21, 2015 at 10:04 AM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On September 21, 2015 3:40:31 AM CDT, "TUAZ TORCHON, Dimitri" <dimitri.tuaztorchon at airbus.com> wrote:
>>I first get the RTEMS Source Builder at
>>"git://git.rtems.org/rtems-source-builder.git". After executing
>>"source-builder/sb-check", I realized Makeinfo was not installed on my
>>computer so I installed it by hand. I then run
>>"../source-builder/sb-set-builder --log=l-microblaze.txt
>>--prefix=/projets/1007/stage/rtos/development/rtems/4.11
>>4.11/rtems-microblaze --without-rtems --without-cxx".
>>My computer has restricted access for downloading files, so when the
>>script tried to download files, I copied the URL provided and
>>downloaded the files on another computer. For RTEMS Tools, the script
>>does a git clone, git reset (hard), git checkout on master and a git
>>pull. As my computer can't do a git clone and a git pull, I did this on
>>another machine and in the file
>>"rtems-source-builder/rtems/config/tools/rtems-tools-1.cfg", line 33, I
>>changed " %source set rtems-tools
>>git://git.rtems.org/rtems-tools.git?reset=hard?branch=master?pull%{rtems_tools_git_checkout}"
>>in " %source set rtems-tools
>>git://git.rtems.org/rtems-tools.git#?reset=hard?branch=master?pull%{rtems_tools_git_checkout}"
>>(I commented the git reset, git checkout and git pull, but did these
>>commands by hand on another computer.).
>>At this stage, the compiler seems to work when I tried it on a simple
>>.c file.
>>Then, I get the RTEMS-microblaze repo on github, run "bootstrap -p" and
>>"bootstrap", "configure" with "../rtems-microblaze/configure
>>--target=microblaze-rtems4.11 --disable-networking --disable-posix
>>--disable-cxx --enable-rtemsbsp=microblaze_fpga --prefix=$HOME/rtems",
>>and during "make all" I've got the error I described.
> When you run bootstrap, are the RTEMS autoconf and automake used? You need the RTEMS tools at the head of your PATH.
> Hesham.. Not at a computer to check but is he using newer tools than you? I don't know if the microblaze tools got bumped when all the others did. Your tools could easily be older and his newer than you have tested.
> Any other environment differences possible?
>>I provide what appears on my shell when executing "make all" (in the
>>file compile_rtems_microblaze.txt).
>>To clarify, I'm working on a computer running on windows 7, but I'm
>>connected and work on a machine running on Red Hat Linux. The computer
>>on which I downloaded and cloned the sources runs on windows.
>>Sent: Friday, September 18, 2015 4:45 PM
>>To: Joel Sherrill
>>On Fri, Sep 18, 2015 at 3:29 PM, Joel Sherrill
>>> I think this is code added after you did the port was done. Hesham..
>>Look at the generic cache code and see what other ports have done.
>>It won't matter, I am using my own repo [1] and didn't update/rebase
>>against master since it was working. I've just cloned and rebuilt it
>>again now, and I got no such error. I suspect Tuaz is missing
>>something. Tuaz, It maybe helpful if you provided full details how you
>>set up the toolchain and RTEMS with configuration options, and full
>>error log.
>>[1] https://github.com/heshamelmatary/rtems-microblaze
>>> On September 18, 2015 8:40:38 AM CDT, "TUAZ TORCHON, Dimitri"
>>>>Yes, I re-downloaded your repo a few hours ago, and run bootstrap –p
>>>>and bootstrap, but I’m having the same error again and again…
>>>>Sent: Friday, September 18, 2015 2:34 PM
>>>>To: TUAZ TORCHON, Dimitri
>>>>Cc: users at rtems.org
>>>>Subject: RE: Difficulties building RTEMS
>>>>Hi,
>>>>I don't know why you are getting this error. Are you sure you're
>>using
>>>>my repo? And have you run bootstrap -p and bootstrap?
>>>>On Sep 18, 2015 10:34 AM, "TUAZ TORCHON, Dimitri"
>>>>Hi,
>>>>Indeed, using RSB is more simple ! I configured it with option
>>>>"--without-rtems" because I want to compile the version with the
>>>>microblaze bsp.
>>>>But when compiling rtems-microblaze (with configuration line
>>--prefix=$HOME/rtems),
>>>>I got an error :
>>>>../../../../../microblaze_fpga/lib/librtemscpu.a(libcsupport_a-cachealignedalloc.o):
>>>>In function `rtems_cache_aligned_malloc':
>>>>/projets/1007/stage/rtos/b-rtems/microblaze-rtems4.11/c/microblaze_fpga/cpukit/libcsupport/../../../../../../rtems-microblaze/c/src/../../cpukit/libcsupport/src/cachealignedalloc.c:18:
>>>>undefined reference to `rtems_cache_get_data_line_size'
>>>>collect2: error: ld returned 1 exit status
>>>>I checked cachealignedalloc.c, and this .c file include <rtems.h>,
>>>>which include <rtems.h/cache.h> in which there is a declaration of
>>>>rtems_cache_get_data_line_size. So I think the error occurs during
>>the
>>>>linking (and one line above, we see that ld returned exit status.)
>>>>In order to see if the linker works, I tried to create an executable
>>>>with a simple .c file, and I got this warning :
>>>>"$HOME/development/rtems/4.11/lib/gcc/microblaze-rtems4.11/4.9.3/../../../../microblaze-rtems4.11/bin/ld:
>>>>warning: cannot find entry symbol _start; defaulting to
>>>>0000000000000050"
>>>>Does this mean that the linker can't find the linker script ? Yet,
>>the
>>>>source builder did not pick up any error...
>>>>Thanks for your help
>>>>Sent: Wednesday, September 16, 2015 11:03 AM
>>>>On Wed, Sep 16, 2015 at 9:54 AM, TUAZ TORCHON, Dimitri
>>>>> I followed the guide "Getting started with RTEMS". But I've found a
>>>>solution : I introduced the "creat()" in libgloss. And then I figured
>>>>out than other functions were missing to (opendir, closed,
>>readdir,...)
>>>>You should use RTEMS Source Builder (RSB) [1] to install the
>>>>MicroBlaze toolchain for RTEMS (if you haven't already). RTEMS is not
>>>>using any libgloss stuff.
>>>>[1] https://docs.rtems.org/rsb/
>>>>> Sent: Wednesday, September 16, 2015 10:43 AM
>>>>> On Tue, Sep 15, 2015 at 9:09 AM, TUAZ TORCHON, Dimitri
>>>>>> Hi,
>>>>>> It's the configuration options I use, but when I make "make all",
>>I
>>>>still have the error :
>>>>>> "checking for creat... no
>>>>>> configure: error: Missing function creat in libc
>>>>>> configure: error: /bin/sh
>>>>'../../../../../rtems-microblaze/c/src/../../cpukit/configure' failed
>>>>for ../../cpukit
>>>>>> gmake[2]: *** [microblaze_fpga] Error 1"
>>>>> How did you install the toolchain?
>>>>>> And indeed, when I check into libc, there is no function creat. I
>>>>figured out that it is an obsolete function now.
>>>>>> Sent: Friday, September 11, 2015 5:01 PM
>>>>>> To: Joel Sherrill
>>>>>> On Fri, Sep 11, 2015 at 3:52 PM, Joel Sherrill
>>>>>>> On 9/11/2015 9:38 AM, Hesham ALMatary wrote:
>>>>>>>> On Fri, Sep 11, 2015 at 2:51 PM, TUAZ TORCHON, Dimitri
>>>>>>>>> Hi,
>>>>>>>>> I’m using your repository, and I get the error I described.
>>>>>>>>> So it is not possible to run complex RTEMS applications on a
>>>>Microblaze ?
>>>>>>>>> I have to use a Spartan6 card.
>>>>>>>> What configuration options do you use? This is a simple
>>>>configuration
>>>>>>>> line the should work: "--target=rtems-microblaze
>>>>>>>> --enable-rtemsbsp=microblaze_fdga --disable-networking
>>>>>>>> --disable-posix"
>>>>>>> I suspect that the argument for the target should be:
>>>>>> Yeah sorry my bad.
>>>>>>>> I am afraid only hello world sample would work. UART is the only
>>>>BSP
>>>>>>>> driver out there for this BSP currently. I got Hello World
>>running
>>>>on
>>>>>>>> Atlys (Spartan 6) board.
>>>>>>> We need to discuss if this is far enough along to merge again now
>>>>that
>>>>>>> we are past a branch. I recall some odd code issues with the
>>vendor
>>>>HAL
>>>>>>> and not running on a simulator at all. But that is a dusty
>>memory.
>>>>>> I didn't run it on the simulator at all, instead I worked
>>directory
>>>>>> with the FPGA. I can see that there's some interest on this port,
>>>>>> which is a good motivation to work on upstreaming it. I'll try to
>>>>>> clean-up the code and send initial patches, but there're no timing
>>>>>> guarantees since I'm pretty busy with school and moving out stuff.
>>>>>>>>> Thanks for your answer,
>>>>>>>>> Dimitri
>>>>>>>>> Sent: Friday, September 11, 2015 3:41 PM
>>>>>>>>> Hi,
>>>>>>>>> What repos are you using to build RTEMS for microblaze? FYI,
>>>>there's no
>>>>>>>>> microblaze port in RTEMS/upstream. I've worked on an initial
>>port
>>>>for it,
>>>>>>>>> you can find it here [1]. It just runs Hello World sample.
>>>>>>>>> Thanks,
>>>>>>>>> Hesham
>>>>>>>>> On Fri, Sep 11, 2015 at 11:04 AM, TUAZ TORCHON, Dimitri
>>>>>>>>> Hi,
>>>>>>>>> I’m trying to build RTEMS for a Microblaze target, but I have
>>>>troubles.
>>>>>>>>> Indeed, the compiler tries to seek “creat()” function in libc,
>>>>but this
>>>>>>>>> function is not in libc.
>>>>>>>>> So it generate an error, and I don’t know how I can fix it….
>>>>>>>>> Thanks a lot,
>>>>>>>>> Dimtiri Tuaz
>>>>>>>>> Ce courriel (incluant ses eventuelles pieces jointes) peut
>>>>contenir des
>>>>>>>>> informations confidentielles et/ou protegees ou dont la
>>diffusion
>>>>est
>>>>>>>>> restreinte. Si vous avez recu ce courriel par erreur, vous ne
>>>>devez ni le
>>>>>>>>> copier, ni l'utiliser, ni en divulguer le contenu a quiconque.
>>>>Merci d'en
>>>>>>>>> avertir immediatement l'expediteur et d'effacer ce courriel de
>>>>votre
>>>>>>>>> systeme. Airbus Defence and Space et les sociétés Airbus Group
>>>>declinent
>>>>>>>>> toute responsabilite en cas de corruption par virus,
>>d'alteration
>>>>ou de
>>>>>>>>> falsification de ce courriel lors de sa transmission par voie
>>>>electronique.
>>>>>>>>> This email (including any attachments) may contain confidential
>>>>and/or
>>>>>>>>> privileged information or information otherwise protected from
>>>>disclosure.
>>>>>>>>> If you are not the intended recipient, please notify the sender
>>>>immediately,
>>>>>>>>> do not copy this message or any attachments and do not use it
>>for
>>>>any
>>>>>>>>> purpose or disclose its content to any person, but delete this
>>>>message and
>>>>>>>>> any attachments from your system. Airbus Defence and Space and
>>>>Airbus Group
>>>>>>>>> companies disclaim any and all liability if this email
>>>>transmission was
>>>>>>>>> virus corrupted, altered or falsified.
>>>>>>>>> Airbus Defence and Space SAS (393 341 516 RCS Versailles) -
>>>>Capital:
>>>>>>>>> 16.587.728 EUR - Siege social: 51-61 Route de Verneuil, 78130
>>Les
>>>>Mureaux,
>>>>>>>>> France
>>>>>>>>> _______________________________________________
>>>>>>>>> users mailing list
>>>>>>>>> users at rtems.org
>>>>>>>>> http://lists.rtems.org/mailman/listinfo/users
>>>>>>>>> Hesham
>>>>contenir des
>>diffusion
>>>>est
>>>>devez ni le
>>>>Merci d'en
>>>>votre
>>>>declinent
>>d'alteration
>>>>ou de
>>>>electronique.
>>>>and/or
>>>>disclosure.
>>>>immediately,
>>for
>>>>any
>>>>message and
>>>>Airbus Group
>>>>transmission was
>>>>Capital:
>>Les
>>>>Mureaux,
>>>>>>>>> France
>>>>>>> Joel Sherrill, Ph.D. Director of Research &
>>Development
>>>>>>> joel.sherrill at OARcorp.com On-Line Applications Research
>>>>>>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>>>>>>> Support Available (256) 722-9985
>>>>>> Hesham
>>>>>> This mail has originated outside your organization, either from an
>>>>external partner or the Global Internet.
>>>>>> Keep this in mind if you answer this message.
>>contenir
>>>>des informations confidentielles et/ou protegees ou dont la diffusion
>>>>est restreinte. Si vous avez recu ce courriel par erreur, vous ne
>>devez
>>>>ni le copier, ni l'utiliser, ni en divulguer le contenu a quiconque.
>>>>Merci d'en avertir immediatement l'expediteur et d'effacer ce
>>courriel
>>>>de votre systeme. Airbus Defence and Space et les sociétés Airbus
>>Group
>>>>declinent toute responsabilite en cas de corruption par virus,
>>>>d'alteration ou de falsification de ce courriel lors de sa
>>transmission
>>>>par voie electronique.
>>>>and/or privileged information or information otherwise protected from
>>>>disclosure. If you are not the intended recipient, please notify the
>>>>sender immediately, do not copy this message or any attachments and
>>do
>>>>not use it for any purpose or disclose its content to any person, but
>>>>delete this message and any attachments from your system. Airbus
>>>>Defence and Space and Airbus Group companies disclaim any and all
>>>>liability if this email transmission was virus corrupted, altered or
>>>>falsified.
>>Capital:
>>>>16.587.728 EUR - Siege social: 51-61 Route de Verneuil, 78130 Les
>>>>Mureaux, France
>>>>> Hesham
>>>>> Ce courriel (incluant ses eventuelles pieces jointes) peut contenir
>>devez
>>courriel
>>Group
>>transmission
>>do
>>>>falsified.
>>Capital:
>>>>Mureaux, France
>>>>Hesham
>>des
>>>>informations confidentielles et/ou protegees ou dont la diffusion est
>>>>restreinte. Si vous avez recu ce courriel par erreur, vous ne devez
>>ni
>>Merci
>>>>d'en avertir immediatement l'expediteur et d'effacer ce courriel de
>>>>votre systeme. Airbus Defence and Space et les sociétés Airbus Group
>>transmission
>>and/or
>>do
>>>>falsified.
>>>>Airbus Defence and Space SAS (393 341 516 RCS Versailles) - Capital:
>>>>Mureaux, France
>>>>*************************************************************** Ce
>>>>courriel (incluant ses eventuelles pieces jointes) peut contenir des
>>ni
>>Merci
>>transmission
>>>>par voie electronique. This email (including any attachments) may
>>>>contain confidential and/or privileged information or information
>>>>otherwise protected from disclosure. If you are not the intended
>>>>recipient, please notify the sender immediately, do not copy this
>>>>message or any attachments and do not use it for any purpose or
>>>>disclose its content to any person, but delete this message and any
>>>>attachments from your system. Airbus Defence and Space and Airbus
>>Group
>>>>companies disclaim any and all liability if this email transmission
>>was
>>>>Mureaux, France
>>> --joel
>>Hesham
>>Ce courriel (incluant ses eventuelles pieces jointes) peut contenir des
>>restreinte. Si vous avez recu ce courriel par erreur, vous ne devez ni
>>le copier, ni l'utiliser, ni en divulguer le contenu a quiconque. Merci
>>d'alteration ou de falsification de ce courriel lors de sa transmission
>>This email (including any attachments) may contain confidential and/or
>>sender immediately, do not copy this message or any attachments and do
>>falsified.
>>Mureaux, France
> --joel
Hesham
This mail has originated outside your organization, either from an external partner or the Global Internet.
Ce courriel (incluant ses eventuelles pieces jointes) peut contenir des informations confidentielles et/ou protegees ou dont la diffusion est restreinte. Si vous avez recu ce courriel par erreur, vous ne devez ni le copier, ni l'utiliser, ni en divulguer le contenu a quiconque. Merci d'en avertir immediatement l'expediteur et d'effacer ce courriel de votre systeme. Airbus Defence and Space et les sociétés Airbus Group declinent toute responsabilite en cas de corruption par virus, d'alteration ou de falsification de ce courriel lors de sa transmission par voie electronique.
This email (including any attachments) may contain confidential and/or privileged information or information otherwise protected from disclosure. If you are not the intended recipient, please notify the sender immediately, do not copy this message or any attachments and do not use it for any purpose or disclose its content to any person, but delete this message and any attachments from your system. Airbus Defence and Space and Airbus Group companies disclaim any and all liability if this email transmission was virus corrupted, altered or falsified.
Airbus Defence and Space SAS (393 341 516 RCS Versailles) - Capital: 16.587.728 EUR - Siege social: 51-61 Route de Verneuil, 78130 Les Mureaux, France
