Workflow RTEMS on Zynq Zedboard
Badr El Hiouel elh.badr at gmail.com
Fri Apr 8 15:07:30 UTC 2016
Hi,  I'm trying to summerize those steps and put the workflow on a diagram.
Attached to this mail , the diagram that I made , Tell me if it's ok or I
have to add or delete something.
I Think a diagram will help for understanding , when we try for the first
time to use RTEMS.
Thank you.
________
*Badr EL HIOUEL*
Mail : elh.badr at gmail.com
2016-03-24 10:26 GMT+01:00 Badr El Hiouel <elh.badr at gmail.com>:
> Thank you Jan for the help.
> In the Zedboard's lab they did the same thing , they didn't create a new
> standalone bsp for the FSBL.
> I did again the steps to build testsuites with rtems ( I tought that the
> probleme maybe come from my file.elf ) and it still don't work.
> Can anybody please tell us how to launch Rtems demos application on the
> Zynq ?
> ​Thank you ​
> ________
> *Badr EL HIOUEL*
> 2016-03-23 18:21 GMT+01:00 Jan Sommer <soja-lists at aries.uberspace.de>:
>> Am 2016-03-23 14:19, schrieb Badr El Hiouel:
>>> Thank you Chris and Jan for your clarifications, its very helpful.
>>> Jan, I found the lab you talked about. I had the zedboard version and I
>>> did
>>> the same steps but it did'nt work.
>>> What I did is to create a hello application + zynq design (from the lab)
>>> generate the FSBL + Xilinx bsp standalone  and then in the option of
>>> create
>>> zynq boot image I changed the hello.elf by ticker.elf. Then , I did
>>> program
>>> flash and it went fine. but when using Tera Ter ( terminal ) with
>>> 115200/8/n/1/n , I have nothing shown in the window ( The LED Done is
>>> blue
>>> and I clicked on BTN7) so I guess that what I did is not working.
>> I just checked it with my setup. In contrast to Figure 1 of tutorial 4 I
>> didn't use the "Create New" option, but "Use existing" and chose the
>> standalone_bsp_0.
>> I followed through with the flash programming and the program ran  after
>> I pressed the reset button.
>> Do you have a solution to how to use an elf file or how to port Rtems
>>> demos to the
>>> board in general ?
>> Well, for us RTEMS on the Zync doesn't have high priority atm, so I only
>> spend some time here or there fiddling with it.
>> Chris made some good points I wasn't aware of (I will have to do some
>> more research to understand everything) and I will see how that applies to
>> us when I find the time, but there's nothing concrete from my side.
>> Cheers,
>>    Jan
>> There is this xilinx
>>> ​tutorial
>>> http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/SDK_Doc/SDK_concepts/concept_faq_debugelfusingsdkwithoutproject.html
>>> But when doing this I can
>>> t create a boot image.
>>> ​Thank you for your help. ​
>>> *Badr *
>>> 2016-03-23 4:40 GMT+01:00 Chris Johns <chrisj at rtems.org>:
>>> On 22/03/2016 21:16, Jan Sommer wrote:
>>>> Then you have the bsp in the Xilinx context. The Zync CPU consists of an
>>>>> ARM-CPU and an FPGA. In order to run any application on the CPU you
>>>>> also
>>>>> have to configure the FPGA, which you do with the bsp and the FSBL from
>>>>> the Xilinx-toolchain.
>>>>> I don't know too much about that configuration so far. I simply
>>>>> followed
>>>>> the tutorial where the FPGA is mainly responsible to connect the CPU to
>>>>> the RAM.
>>>> The Xilinx BSP code is installed as part of the SDK and is available for
>>>> you to use and review. Check the license as it does not allow you to
>>>> make
>>>> that code public.
>>>> When you create an SDK "application" various parts of the SDK BSP code
>>>> is
>>>> copied into your work area and built. What is copied depends on the
>>>> type of
>>>> application you create. There is a nasty gota here. If you need to edit
>>>> the
>>>> BSP code, for example to change the default PHY mode for the GigE MAC to
>>>> support an STP interface the SDK notices and kindly refreshes the copy
>>>> from
>>>> the original without saying a word about it. You can argue this is all
>>>> ok
>>>> except the Xilinx SDK BSP has bugs, for example the BSP ethernet driver
>>>> for
>>>> the Zynq cannot operate close to gigbit speeds. Do you need to update
>>>> the
>>>> original code in the SDK? How do you configuration manage this with a
>>>> team
>>>> of users? The SDK does make nice sample app videos.
>>>> Another simple test is to compile some of the Xilinx BSP code with the
>>>> RTEMS compiler which is a newer version of gcc and watch the warnings.
>>>> For me the important issue with the Xilinx hardware tools and SDK is
>>>> their
>>>> close integration. The hardware designer tools and the SDK versions
>>>> need to
>>>> match. If your FGPA design team need a new version to resolve an issue
>>>> the
>>>> SDK needs to upgrade. What if the newer SDK has an issue? You are
>>>> wedged.
>>>> This interaction works both directions.
>>>> My approach to the Zynq is to keep the hardware design work-flow for the
>>>> FPGA team completely detached from the software work-flow. This means
>>>> software and hardware can each control and manage the versions of the
>>>> tools
>>>> they need to complete the work they need to do.
>>>> Further to this I suggest taking a sample of the FSBL code from the SDK
>>>> and creating a separate custom project and lock it down. Then build this
>>>> code with the RTEMS compiler. The means the project only need to
>>>> configuration manage the hardware design tools and the RTEMS tools. The
>>>> only wrinkle in this is `bootgen` from the SDK and I hope one day an
>>>> open
>>>> source version appears.
>>>> There is a side effect of this and that is loading the bitfile which the
>>>> SDK magically embeds in the FSBL. I have RTEMS load the bitfile from SD
>>>> or
>>>> flash. I consider the Xilinx documented single image with the FSBL,
>>>> bitfile
>>>> and the application as a configuration nightmare and a bricking risk.
>>>> IMO
>>>> even the golden images that can be supported by the Zynq's BootROM code
>>>> can
>>>> have issues. I use [1] to load RTEMS from a JFFS2 from my hacked FSBL.
>>>> Finally an unrelated note, there is hidden requirement for the FSBL
>>>> structure, coding etc. A Zynq as a PCI Express device needs to load the
>>>> bitfile and boot in under 100msecs or it misses the PCI express host
>>>> probes
>>>> and it not seen.
>>>> Chris
>>>> [1] https://ftp.rtems.org/pub/rtems/people/chrisj/jffs2-boot/
URL: <http://lists.rtems.org/pipermail/users/attachments/20160408/e5c282a8/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20160408/e5c282a8/attachment-0001.png>
