Loading RTEMS-application with U-boot on Raspberry Pi or MicroZed
Jan Sommer soja-lists at aries.uberspace.de
Mon Apr 11 13:43:52 UTC 2016
TOFU:
I just tried the same setup with the Xilinx MicroZed board at work.
There, the same behaviour appears.
If I compile a simple bare metal application I can load the binary to
the correct address and run it or load the elf-file somewhere into the
memory and use the bootelf-command to start the application.
If I try to do the same with a compiled RTEMS-application, it won't
work. The same RTEMS-application runs if I put it directly into the
bootimage (without using u-boot).
How does it work on other ARM-boards? The BeagleBone uses u-boot to load
all its binaries, doesn't it?
Best regards,
    Jan
Am 2016-04-07 00:33, schrieb Jan Sommer:
> Hello,
> I tried (and failed) again to start an RTEMS-application for the
> raspberry pi using u-boot.
> If I start the same binary file directly from the sd-card (i.e.
> renaming it to kernel.img) it works fine.
> In order to test my u-boot I compiled some of the baremetal programs
> from [1].
> There, I can load the binary directly to address 0x8000 and start it
> with go and I can load the elf-file somewhere into the memory (e.g.
> 0x100000) and use bootelf to run the program. Both works fine.
> However as soon as I try the same mechanisms with a similar
> RTEMS-application which simply blinks an LED the program never starts.
> If I look at the output of readelf for the RTEMS-program [2] I noticed
> that the entry point address is not 0x8000, but 0x8040.
> In comparison the elf-file of the baremetal program [3] has entry
> point address 0x8000 and under "Flags" it says  "has entry point".
> I am not very experienced when it comes to linker scripts and
> elf-format, so I am not sure how to interpret all the different
> information. Am I on the right track at all here?
> Has someone else managed to run RTEMS-applications using u-boot (even
> on a different platform)?
> Best regards,
>    Jan
> [1] https://github.com/dwelch67/raspberrypi
> [2] blinker-rtems/o-optimize$ arm-rtems4.12-readelf -e
> blinker-rtems.exe
> ELF Header:
>   Magic:   7f 45 4c 46 01 01 01 00 00 00 00 00 00 00 00 00
>   Class:                             ELF32
>   Data:                              2's complement, little endian
>   Version:                           1 (current)
>   OS/ABI:                            UNIX - System V
>   ABI Version:                       0
>   Type:                              EXEC (Executable file)
>   Machine:                           ARM
>   Version:                           0x1
>   Entry point address:               0x8040
>   Start of program headers:          52 (bytes into file)
>   Start of section headers:          3492848 (bytes into file)
>   Flags:                             0x5000200, Version5 EABI,
> soft-float ABI
>   Size of this header:               52 (bytes)
>   Size of program headers:           32 (bytes)
>   Number of program headers:         4
>   Size of section headers:           40 (bytes)
>   Number of section headers:         34
>   Section header string table index: 31
> Section Headers:
>   [Nr] Name              Type            Addr     Off    Size   ES Flg
> Lk Inf Al
>   [ 0]                   NULL            00000000 000000 000000 00
> 0   0  0
>   [ 1] .start            PROGBITS        00008000 0000b4 000348 00  AX
> 0   0  4
>   [ 2] .xbarrier         PROGBITS        00000000 010640 000000 00   W
> 0   0  1
>   [ 3] .text             PROGBITS        00008348 0003fc 00ef88 00 WAX
> 0   0  4
>   [ 4] .init             PROGBITS        000172d0 00f384 000018 00  AX
> 0   0  4
>   [ 5] .fini             PROGBITS        000172e8 00f39c 000018 00  AX
> 0   0  4
>   [ 6] .robarrier        NOBITS          00017300 00f3b4 0e8d00 00  WA
> 0   0  1
>   [ 7] .rodata           PROGBITS        00100000 00f3c0 000c51 00   A
> 0   0  4
>   [ 8] .ARM.exidx        ARM_EXIDX       00100c54 010014 000008 00  AL
> 3   0  4
>   [ 9] .eh_frame         PROGBITS        00100c5c 01001c 000004 00   A
> 0   0  4
>   [10] .init_array       INIT_ARRAY      00100c60 010020 000004 00  WA
> 0   0  4
>   [11] .fini_array       FINI_ARRAY      00100c64 010024 000004 00  WA
> 0   0  4
>   [12] .jcr              PROGBITS        00100c68 010028 000004 00  WA
> 0   0  4
>   [13] .rtemsroset       PROGBITS        00100c6c 01002c 000038 00  WA
> 0   0  4
>   [14] .rwbarrier        PROGBITS        00100ca4 010640 000000 00   W
> 0   0  1
>   [15] .vector           NOBITS          00000000 0000b4 001440 00  WA
> 0   0  1
>   [16] .data             PROGBITS        00100ca8 010068 0005d8 00  WA
> 0   0  8
>   [17] .bss              NOBITS          00101280 010640 0018f0 00  WA
> 0   0 32
>   [18] .work             NOBITS          00102b70 010640 7ef9490 00
> WA  0   0  1
>   [19] .stack            PROGBITS        07ffc000 010640 000000 00   W
> 0   0  1
>   [20] .nocachenoload    PROGBITS        07ffc000 010640 000000 00   W
> 0   0  1
>   [21] .comment          PROGBITS        00000000 010640 000075 01  MS
> 0   0  1
>   [22] .debug_aranges    PROGBITS        00000000 0106b8 002cf8 00
> 0   0  8
>   [23] .debug_info       PROGBITS        00000000 0133b0 27217b 00
> 0   0  1
>   [24] .debug_abbrev     PROGBITS        00000000 28552b 03004c 00
> 0   0  1
>   [25] .debug_line       PROGBITS        00000000 2b5577 050cb6 00
> 0   0  1
>   [26] .debug_frame      PROGBITS        00000000 306230 0051c8 00
> 0   0  4
>   [27] .debug_str        PROGBITS        00000000 30b3f8 0152f2 01  MS
> 0   0  1
>   [28] .debug_loc        PROGBITS        00000000 3206ea 020a63 00
> 0   0  1
>   [29] .debug_ranges     PROGBITS        00000000 34114d 0059e0 00
> 0   0  1
>   [30] .ARM.attributes   ARM_ATTRIBUTES  00000000 346b2d 000036 00
> 0   0  1
>   [31] .shstrtab         STRTAB          00000000 354aa8 000148 00
> 0   0  1
>   [32] .symtab           SYMTAB          00000000 346b64 008ab0 10
> 33 1649  4
>   [33] .strtab           STRTAB          00000000 34f614 005494 00
> 0   0  1
> Key to Flags:
>   W (write), A (alloc), X (execute), M (merge), S (strings)
>   I (info), L (link order), G (group), T (TLS), E (exclude), x
> (unknown)
>   O (extra OS processing required) o (OS specific), p (processor
> specific)
> Program Headers:
>   Type           Offset   VirtAddr   PhysAddr   FileSiz MemSiz  Flg
> Align
>   EXIDX          0x010014 0x00100c54 0x00100c54 0x00008 0x00008 R   0x4
>   LOAD           0x0000b4 0x00000000 0x00000000 0x00000 0x01440 RW  0x1
>   LOAD           0x0000b4 0x00008000 0x00008000 0x0f300 0xf8000 RWE 0x4
>   LOAD           0x00f3c0 0x00100000 0x00100000 0x01280 0x7efc000 RW
> 0x20
>  Section to Segment mapping:
>   Segment Sections...
>    00     .ARM.exidx
>    01     .vector
>    02     .start .text .init .fini .robarrier
>    03     .rodata .ARM.exidx .eh_frame .init_array .fini_array .jcr
> .rtemsroset .data .bss .work
> [3] blinker02/plus$ arm-none-eabi-readelf -e blinker02.elf
> ELF Header:
>   Class:                             ELF32
>   ABI Version:                       0
>   Machine:                           ARM
>   Version:                           0x1
>   Entry point address:               0x8000
>   Start of section headers:          33424 (bytes into file)
>   Flags:                             0x5000202, has entry point,
> Version5 EABI, soft-float ABI
>   Number of program headers:         1
>   Number of section headers:         7
>   Section header string table index: 4
> Section Headers:
> Lk Inf Al
> 0   0  0
>   [ 1] .text             PROGBITS        00008000 008000 0000bc 00  AX
> 0   0  4
>   [ 2] .ARM.attributes   ARM_ATTRIBUTES  00000000 0080bc 00002b 00
> 0   0  1
>   [ 3] .comment          PROGBITS        00000000 0080e7 000038 01  MS
> 0   0  1
>   [ 4] .shstrtab         STRTAB          00000000 00811f 00003a 00
> 0   0  1
>   [ 5] .symtab           SYMTAB          00000000 00815c 0000f0 10
> 6  10  4
>   [ 6] .strtab           STRTAB          00000000 00824c 000043 00
> 0   0  1
> Key to Flags:
> (unknown)
> specific)
> Program Headers:
> Align
>   LOAD           0x000000 0x00000000 0x00000000 0x080bc 0x080bc R E
> 0x10000
>   Segment Sections...
>    00     .text
> users mailing list
> users at rtems.org
