Is there any framebuffer testcases?
Wed Apr 13 08:58:43 UTC 2016
On 13/04/16 10:44, Peng Fan wrote:
> I saw this patch added _Mutex_recusive_Acquire and applied to
> newlib.https://sourceware.org/ml/newlib/2015/msg00583.html
> In this patch, i did not see the function definiton. Is it the reason
> that cause `undefined reference`? If need to implement
> `_Mutex_recursive_Release`, should make it in rtems code base or
> newlib code base? I have no clear idea on this.
It is defined here:
https://git.rtems.org/rtems/tree/cpukit/score/src/mutex.c
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
