Is there any framebuffer testcases?
Peng Fan
van.freenix at gmail.com
Wed Apr 13 08:44:18 UTC 2016
I saw this patch added _Mutex_recusive_Acquire and applied to newlib.
https://sourceware.org/ml/newlib/2015/msg00583.html
In this patch, i did not see the function definiton. Is it the reason that
cause `undefined reference`? If need to implement `_Mutex_recursive_Release`,
should make it in rtems code base or newlib code base? I have no clear idea
on this.
Thanks,
Peng.
2016-04-13 16:07 GMT+08:00 Chris Johns <chrisj at rtems.org>:
> On 08/04/2016 11:45, Chris Johns wrote:
>> The test is simple:
>> $ cat hw.c
>> #include <stdio.h>
>> int main(void)
>> printf("hello world\n");
>> return 0;
>> $ arm-rtems4.12-gcc -o hw hw.c
> The actual failing test case used by configure is attached. It would seem
> changes to newlib or gcc have broken building 3rd party packages.
> A fix would be nice. :)
> Thanks
> Chris
> $ i386-rtems4.12-gcc -o conftest conftest.c
> /opt/work/rtems/4.12/lib/gcc/i386-rtems4.12/6.0.0/../../../../i386-rtems4.12/bin/ld:
> warning: cannot find entry symbol _start; defaulting to 0000000008048074
> /opt/work/rtems/4.12/lib/gcc/i386-rtems4.12/6.0.0/../../../../i386-rtems4.12/lib/libc.a(lib_a-fclose.o):
> In function `_fclose_r':
> /opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/fclose.c:117:
> undefined reference to `_Mutex_recursive_Release'
> /opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/fclose.c:86:
> undefined reference to `_Mutex_recursive_Acquire'
> /opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/fclose.c:91:
> /opt/work/rtems/4.12/lib/gcc/i386-rtems4.12/6.0.0/../../../../i386-rtems4.12/lib/libc.a(lib_a-fflush.o):
> In function `_fflush_r':
> /opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/fflush.c:282:
> /opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/fflush.c:280:
> /opt/work/rtems/4.12/lib/gcc/i386-rtems4.12/6.0.0/../../../../i386-rtems4.12/lib/libc.a(lib_a-findfp.o):
> In function `__fp_lock':
> /opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/findfp.c:297:
> In function `__fp_unlock':
> /opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/findfp.c:308:
> In function `__sinit_lock_acquire':
> /opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/findfp.c:282:
> In function `__sfp_lock_acquire':
> /opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/findfp.c:270:
> In function `__sfp_lock_release':
> /opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/findfp.c:276:
> In function `__sinit_lock_release':
> /opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/findfp.c:288:
> /opt/work/rtems/4.12/lib/gcc/i386-rtems4.12/6.0.0/../../../../i386-rtems4.12/lib/libc.a(lib_a-fopen.o):
> In function `_fopen_r':
> /opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/fopen.c:152:
> /opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/fopen.c:170:
> /opt/work/rtems/4.12/lib/gcc/i386-rtems4.12/6.0.0/../../../../i386-rtems4.12/lib/libc.a(lib_a-fseeko.o):
> In function `_fseeko_r':
> /opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/fseeko.c:157:
> /opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/fseeko.c:141:
> /opt/work/chris/rtems/rsb/rtems-source-builder.master/rtems/build/i386-rtems4.12-gcc-6-20160327-newlib-2.4.0-x86_64-freebsd10.1-1/build/i386-rtems4.12/newlib/libc/stdio/../../../../../gcc-6-20160327/newlib/libc/stdio/fseeko.c:318:
URL: <http://lists.rtems.org/pipermail/users/attachments/20160413/47f95e0a/attachment.html>
